Sponsored by: Kumho
Rag Joint
Old Aug 5, 2004 | 10:24 PM
Quackhead94ranger's Avatar
Quackhead94ranger
Rag Joint
my brother has a 1978 ford f150 ranger and he needs a new rag joint for it, alls he need is the ragjoint, not the steering shaft thing a majiggerdoodle, were would be the best place to find one of these? i did some searching but was only able to find the steering thinger ragjoint, thanks for the help
quack
Old Aug 5, 2004 | 10:25 PM
Mil1ion's Avatar
Mil1ion
Go to your local auto parts dealer and look in their H.E.L.P. section of assorted parts.
You will find one for about $7.00
You can follow along with this thread in the steering forum.
Old Aug 5, 2004 | 10:28 PM
Quackhead94ranger
wow that was fast, i appreciate that!!! thanks!
quack
Old Aug 5, 2004 | 10:30 PM
Mil1ion's Avatar
Mil1ion
Sometimes you get a reply in the break-neck speed of 3 days
You lucked out
Old Aug 6, 2004 | 09:43 AM
toolz_not_toyz's Avatar
toolz_not_toyz
I just did this recently on my truck. In the HELP section you may find two products that state they will fit Ford. The parts are different inside. If I remember correctly, one of them had more bolts or something like that. In general, you will need to grind off the safety studs in order to get the old ragjoint out (just so you know, in HELP they won't have the complete assy. you will just get the rubber part and some hardware). You will then need to select the correct bolt thingies to replace those studs.
The far superior fix, however, is to install u joints (knuckles) instead of a rag joint and I plant to upgrade to that setup when I replace the steering gear.
Old Aug 6, 2004 | 10:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
The rag joint is also a vibration isolator. If you don't have one road vibration from the frame is transmitted thru the steering wheel to your hands. You will probably not notice the vibration but your hands on the wheel will go numb on longer trips.
Old Aug 6, 2004 | 10:15 PM
73effie's Avatar
73effie
also, to make things a little bit easier (but more expensive), places like NPD and the sort sell a reproduction complete ragjoint assembly. the dealer does not, however.
eddie-
Old Aug 7, 2004 | 01:37 AM
Quackhead94ranger
haha, well my brother went to autozone and the ppl there decided that there is no such thing as a ragjoint haha
but thanks for the other info i will be sure to tell him about that!
what is "help"???
Drpomaville
Jul 10, 2016 09:54 AM
vidaliaman
May 13, 2016 11:43 AM
stercorarius
Mar 14, 2015 11:15 PM
eduardo
1978 - 1996 Big Bronco
Oct 11, 2005 12:05 AM
longview1
Jun 8, 2004 07:55 PM
