Overdrive light blinking but no codes
Old Jan 26, 2010 | 12:17 AM
Hiflyer746's Avatar
Hiflyer746
What were the codes?
Timmy
Old Jan 26, 2010 | 12:54 PM
dustmaker37's Avatar
dustmaker37
Originally Posted by dustmaker37
Hi,
I have a 2001 F-250 7.3 powerstroke diesel and my overdrive button was flashing after i worked it alittle when i had to pull my wife out of the snow. The trans temp was about 134 degrees so i let the truck sit for about ten minutes to cool down then turned it off and back on to see if it changed and it did. The light stopped flashing. Did i just over heat it or is something seriously wrong?
Thanks
thanks onelionhunter
i took the truck for spinn this morning and everything seems to be fine.
the DSS sensor ,should i change it or let it alone?
Old Jan 26, 2010 | 03:30 PM
onelionhunter's Avatar
onelionhunter
for now
For now, I wouldn't worry about it. if your speedo quits and you start getting the flashing OD light again, then pull it and clean it, or swap it. It is right on top of your rear pumpkin. 170 isn't that hot, I don't think you did anything to the tranny at that temp.
Old Jan 26, 2010 | 06:30 PM
HKusp's Avatar
HKusp
Not to bust chops but i believe it's referred to as the VSS sensor. It's the Vehicle Speed Sensor I think.
Old Jan 26, 2010 | 09:19 PM
mach1boy's Avatar
mach1boy
flashing lite
i have a 03 550 with390,000 klms on it,i had the trans rebuilt last may and put about 35,000klms on it a my lite was flshing .took it back in and it was the soliniod pack that was faulty,they replaced it no charge, so i hope this one holds up longer
Old Aug 16, 2011 | 11:24 AM
AnnesLimo's Avatar
AnnesLimo
O'D blinking, key in ignition chime...
OK folks I may have discovered the culprit of this and possibly other issues that seem to have no evident cause as well as some intermittancy.
First a little history on my deductive thinking. Last year we were having trouble with my daughter's Zuki GV and stalling running sputtering... Long story short after trying everything that would be obvious including the cat we discovered water had accumulated in the OBC because the A/C drain tube was clogged with a dead insect... The intermittency of her problem was because no A/C use = dry OBC = no problem then run the A/C awhile = problem...
Fast forward to today... 2 days ago I went out to my driveway and found my remote control would not open the door locks or function at all. While approaching my truck I heard the radio playing and noticed the clock display was on? After unlocking the door and entering the key in ignition chime would not turn off after the key was removed and the door was ajar. Prior to these discoveries while driving earlier that same day I noticed my OD light blink but my tranny was shifting and functioning fine. Last but certainly not least the Service Engine Light soon lit up!!!
As anyone can imagine I immediately started checking fuses, relays and wiring harnesses / connections, all which appeared to have no issues. Next I pulled and cleaned the ignition key cylinder and no change in the issues. Backing up a little last month I replaced the shift lever with O/D but and wire due to the original having been chafed beyond repair so I next removed the steering column covers to inspect the wiring and connections there to no avail - no problem.
Hmm, so now I'm stumped and I turn to the internet... After reading several posts, comments, suggestions and frustrations I called it a night.
Today I proceeded to enter the truck and noticed there was a little puddle of water that had accumulated on the dash panel fuse box access cover I had left laying on the drivers side floor.
Upon further investigation I discovered the drip evidently was comming from above the fuse panel and guess what is above the fuse panel????
Bingo the OBC and it appears that somehow water from the downpoor we had the day before has seeped into that black box...
Anyone who knows anything about electronics and water knows the two do not get along well!!! I took pictures. Now the question is how and where did the water get there???
The moral of the story; If funny things start happening that appear to be electrical in nature then before you start replacing components or tearing down trannys look for water in places it doesn't belong!!!
Thanks go out to the little blue Zuki GV my daughter so obligingly allowed to be our ginnea pig a year before....
Just a follow up thought;
I am now wondering if this has been a prolonged issue creating intermittent operational problems that appeared to be failing coil packs, dirty spark plugs, bad fuel, failing injectors et.. et.. et...
As I rewind in my mind and think about times when it appeared I was getting a misfire in my V10 I wonder if it was a coil pack or the result of water / moisture penetration since the issues with rough idle and or misfires allways seemed to appear after or during winter or wet rainy days???
Hmmm, pondering the possibilities of a small issue creating big problems across a wide spectrum of modern vehicle technology. One day it's there and the next day it's gone... Climbing uphill under acceleration and the A/C running switchs damper door to defrost vents instead of dash vents, door ajar warnings, airbag SRS warning lights, inaccurate speedometer as compared to GPS speed tracking and maybe the inaccurate fuel guage which still has 8 gallons of fuel on below empty and 0 miles to empty....
My oh my the possibilities are infinate!!! Lions and Tigers and Water in my OBC?
Old Aug 16, 2011 | 11:48 AM
AnnesLimo's Avatar
AnnesLimo
bump. edited previous post and need this duplicate deleted...
Old Aug 17, 2011 | 09:43 AM
Brother Les's Avatar
Brother Les
The water is coming in around your windshield. That needs to be checked and fixed. There many threads of electrical issues that have been traced to water coming from under the dash. The vast majority of the water is coming form leaking windshield rubber. If you do not get it fixed now, the next time that you are driving in the rain your truck my start doing all types of screwy things.
thr57
1997 - 2003 F150
Jul 17, 2017 09:30 PM
CASHER0010
Mar 27, 2015 03:59 AM
smashclash
1997 - 2003 F150
45
Sep 17, 2014 02:17 PM
kattywumpus
1997 - 2003 F150
Oct 12, 2010 07:23 PM
fordman1090
Sep 28, 2009 06:09 PM
