Blinking ABS Light
Old Sep 27, 2009 | 09:11 PM
fordman1090's Avatar
fordman1090
Blinking ABS Light
The ABS light on my 93 F150 started blinking earlier this evening. And it has been blinking ever sense. I was making a right hand turn and the light came on for 2-3 seconds, then went off for 2-3 seconds, then started blinking 15 short blinks then 1 long, no brake lights as well. I did a search and learned that it is most often a blown fuse. But mine isnt. i pulled codes and got 522 KOEO. I haven't been able to find the code.
Any ideas of where i should start looking?
Old Sep 27, 2009 | 09:32 PM
skyfox10's Avatar
skyfox10
On weekends, I work for a farmer with a 96 or 97 F350 with a similar problem. Spliced from, what I believe is the some of the wiring for the trailer, wires go into the camper cap for an internal light. I'm not sure if there is brake lights & blinkers on the cap as well.
Anyway, whoever set this up, was a bit sloppy and the the insulation is getting worn away causing a short . Anyway, whenever the camper cap is connected, the ABS light blinks regularly, when you disconnect the wiring going to the camper cap, it stops.
You may check any wiring that may go to a trailer or if you have a trailer brake controller, check it. Otherwise, maybe have someone watch to see if all of your brake lights work.
We never found out exactly what wires are shorting so I can't be more specific but it should be a place to start. Also, check any fuses for anything brake/blinker/lighting related. Let we know what you find.
Old Sep 27, 2009 | 10:48 PM
fordman1090
I checked my tail lights and they dont work. But like i said the fuse isnt broken. Ill try putting in a different fuse tomorrow just in case, even though its appears to be good.
Old Sep 27, 2009 | 11:13 PM
17fordguy's Avatar
17fordguy
well along the same subject i am having a similar problem. 3 blinksthen 2 blinks what could this be any help appreciated. sorry for the hijack
Old Sep 28, 2009 | 06:09 PM
fordman1090
Well, this morning i got a chance to look into it more. I found that i had blown the 50AMP fuse in the engine comparment. And i figured out that, it is the same fuse that the empty fuse slot i was using in the cab for my radios and that i had temperarly wired a BIG 12v compressor using alligator clamps which i think shored and blew it. But i think its all fixed now.
Thanks for the help, and sorry fordguy the solution probably wasn't to helpful. Good Luck
couverley
May 7, 2017 11:41 AM
Daniel Simmons
Modular V8 (4.6L, 5.4L)
Apr 19, 2017 08:32 AM
23zuklin
Feb 26, 2016 12:47 PM
CASHER0010
Mar 27, 2015 03:59 AM
smashclash
1997 - 2003 F150
45
Sep 17, 2014 02:17 PM
