Check engine light...
Old Aug 5, 2004 | 07:22 PM
D-ranged2.5's Avatar
D-ranged2.5
Ugh... not the kind of thing you want to see when you've got a 70 mile drive to and from work every day...
I went to Autozone and they gave me one of those code slips... says the EGR valve is malfunctioning. I drive a 2001 2.5 5 speed. Anybody know much about this? I haven't had a lot of time to tinker with it, but since it's mine, I know I have to fix it. I also have to replace half of the bulbs in my instrument cluster... but I'll keep holding off until absolutely necessary. Thanks in advance!
Old Aug 5, 2004 | 07:45 PM
Ken00's Avatar
Ken00
Did they give you the code number(s)?
Replace all the bulbs when you do it, otherwise the other half will go the next day.
Old Aug 6, 2004 | 09:12 AM
D-ranged2.5
Yeah, I have the code numbers at home. I'll get that when I go home tonight. And thanks! I never would have thought to change them all...
Old Aug 6, 2004 | 04:42 PM
Neuro's Avatar
Neuro
I have 98 3.0 with the same prob. I noticed the check light about a week ago.
The engine has a rough idle and runs kinda rough. I went to Autozone, they checked it and told me it could be one of three things,EGR valve, sensor,forgot what else, anyway I bought a EGR valve for $52, I changed it, because the old one was full of carbon and had poor suction, my trucks idle is now smoother but is still rough while driving at certain times, and the check light still on . I guess I will try changing the EGR sensor next, another $52. (strange they both cost $52)
Old Aug 6, 2004 | 08:27 PM
Ken00's Avatar
Ken00
The DPFE senser is the common cause of an EGR code on the 3.0s.
Old Aug 6, 2004 | 08:31 PM
D-ranged2.5
Got it! Code reads:
P0402
EGR Flow
Excessive
Last edited by D-ranged2.5; Aug 6, 2004 at 08:37 PM. Reason: wrong code first time
Old Aug 6, 2004 | 08:42 PM
Ken00's Avatar
Ken00
Run this test...
DPFE-Voltage-Test
Old Aug 8, 2004 | 01:56 AM
Neuro's Avatar
Neuro
yes, I changed the $52 DPFE senser yesterday, problem solved
Old Aug 8, 2004 | 07:17 PM
Ken00's Avatar
Ken00
Kool!!!!!!
Old Aug 11, 2004 | 04:19 AM
mfpengineer's Avatar
mfpengineer
If your dpfe sensor is gone bad will that affect your gas mileage? My check engine light has been on for at least 1000 miles now. I have a 2001 quad cab (43,000 miles) w/4.0, auto trans, 31.10.50 tires and my mileage absolutely sucks. Prob only getting around 15mpg @ best. Best I can do on a tank is 225 miles and you had better be finding petro quick.
SuperDuty93
Jan 19, 2014 10:47 AM
GCLL
6.7L Power Stroke Diesel
19
Oct 2, 2010 08:10 PM
JaysRanger
Engine Swaps
Nov 20, 2009 11:51 PM
Fishrman
Offroad & 4x4
13
Mar 10, 2004 09:29 PM
ftrucktough
1978 - 1996 Big Bronco
Sep 24, 2002 12:02 PM
