Passenger window woes
Old Aug 4, 2004 | 08:18 PM
Packerman's Avatar
Packerman
I have a 1997 Aerostar. The passenger window will not work from either the drivers or passenger switch. For a short while, it would work if I opened the drivers door and wiggled the wiring boot in the drivers door. Even this does not work now. Anyone with any ideas.
PS - The drivers window works fine.
Old Aug 4, 2004 | 09:17 PM
Gary B's Avatar
Gary B
watch the interior lights(dome light) if it dims when you work the switch,replace the motor.
Old Aug 5, 2004 | 12:48 PM
Franklin2's Avatar
Franklin2
Sounds like the wiring is bad in the door jamb area from your description, especially if in Gary B's test the light doesn't dim.
Old Aug 5, 2004 | 01:19 PM
1081's Avatar
1081
Sometimes you may be able to take the door panel off (the passenger side) and tap on the motor with a hammer and it may work again. If this does happen then it is the window motor. (If it does work it is only temporary don't rely on it to keep working).
Old Aug 5, 2004 | 03:23 PM
73Custom's Avatar
73Custom
That makes it clear it's a bad wire between the driver door and the dash. Work the boot loose and inspect/repair the wires. Very common problem.
Marty
buzznuts
Aerostar
Nov 12, 2012 05:21 AM
400Nut
Aerostar
Sep 6, 2012 02:44 PM
krehjc
Paint & Bodywork
Jun 14, 2011 05:42 PM
kable
Electrical Systems/Wiring
Aug 23, 2004 09:44 PM
3vanman
Aerostar
Dec 21, 2003 04:55 PM
