Help!!!!
Old Aug 4, 2004 | 04:48 PM
ASE's Avatar
ASE
Help!!!!
I need help from my fellow Ford brothers!
I just got back from dealership, my truck was in because of a fuel leak. They said its all fixed and ready to go. I also had a brand new Fisher X-Blade 8 ft plow installed while it was there for the 2 days. well I picked it up and I was on my way hoping that the problems are all gone, I made it about 5 miles down the road when I noticed the truck was over heating and was in the red for a I don't know how long. I immediately pulled over and shut down, while I was sitting there letting the truck cool down I called the dealership and told them to get a tow truck.
I am now back in the rental car again!!
has anyone had this problem with the plows mounted, before anyone asks I had the plow off the ground about 4 inches so the radiator was getting air. This is definitely a coolant problem in my eyes. Is there a TSB out on this problem?
I am not getting a real good feeling about this truck as it only has a 1000 miles on it. Also do you think I hurt the motor running this hot, I am guessing it ran hot for about 5 min. I also told them to change the oil while it was in again.
Old Aug 4, 2004 | 06:00 PM
ASE's Avatar
ASE
I forgot to mention the truck, F-350 2004 6.0L PSD engine made 5/04 CC/SB SRW.
Old Aug 4, 2004 | 06:11 PM
jdadamsjr's Avatar
jdadamsjr
Did the dealer mount the plow ????
Sounds like they may have done an Oops...
like one did on my $75K motorhome one time...
Flush and filled the radiator...
but forgot that second part (the fill) !
they bought it from me !
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
You seem to be having some problems!
Old Aug 4, 2004 | 06:21 PM
ASE's Avatar
ASE
Yes the dealer mounted the plow, and after tomorrow if the problem is not fixed I am towing it to a real service tech that knows what they are doing. I am really worried if I hurt the engine driving it that hot. I wish ford would make an Audio warning with a flashing check engine light instead of the what they have now.Disgusted
Old Aug 4, 2004 | 07:46 PM
FF-Paramedic's Avatar
FF-Paramedic
Saw this on another site. Not sure if it will help.
From Dieselmann's website.
Broadcast message from Ford in early march.
03/04 F-Series Overheating with Snow Plow Installed:
If a snow plow is installed on a truck with the 6.0, it may disrupt the air flow through the front of the truck causing the cooling fan to stop or turn in reverse. For trucks with snow plows there is a revised fan clutch available (P/N 4C3Z-8A616-SA). Some trucks have been modified with a jumper on the fan connector to keep the fan continuously engaged. This jumper must be removed before connecting the new fan. Broadcast Message 1137.
Old Aug 4, 2004 | 08:34 PM
ASE's Avatar
ASE
Thanks for the information FF-PARAMEDIC.
My real concern was the engine running Red-Line for maybe 5 minutes and I am worried if any damage could have happend. forget about getting a straight answer from a service manager about the engine running hot, he said it would take 30 minutes or more for damage to occur, I dont believe that and I think they are trying to cover their own MISTAKE.
Old Aug 4, 2004 | 09:11 PM
jdadamsjr's Avatar
jdadamsjr
Good luck...
Here's hopint U will be all right...
just so long as you let it cool naturally....
Menghi08LT
Sep 2, 2011 02:02 AM
mkeller1397
Nov 9, 2010 06:01 AM
cjcocn
Jan 24, 2010 02:24 PM
1977f150xlt
16
Oct 9, 2009 01:18 AM
Got Snow
Mar 29, 2004 09:10 AM
