EGR Disconnect = Engine Light
Old Aug 2, 2004 | 01:59 PM
chandlerbf's Avatar
chandlerbf
Unplugged my EGR valve yesterday and it made my engine light come on. So I plugged it back in and the light went away after a few starts. Did anybody else have their light come on? My truck is an 04/04 F350. I believe I read of somebody getting a failed EGR valve someplace and using that?
Old Aug 2, 2004 | 02:03 PM
kw5413's Avatar
kw5413
Go to the EGR Disconnect sticky on 6.0 forum page. Much duscusion there. Lots of reading. Some getting light...some are not.
Did you unplug while engine off?
FYI: No check engine light for me.
Old Aug 2, 2004 | 02:21 PM
jdadamsjr's Avatar
jdadamsjr
Is it just the later 04's that are giving a chk engine lite ?
Old Aug 2, 2004 | 02:26 PM
kw5413's Avatar
kw5413
Could be...my '04 engine build date is 10/03. No check engine light.
Old Aug 2, 2004 | 03:04 PM
psdwanabe's Avatar
psdwanabe
No, California and related states (emissions) engines will turn on the light with EGR disconnect.
Old Aug 2, 2004 | 04:10 PM
Daryl Hunter's Avatar
Daryl Hunter
Mine is an 02/03 CA model with the emissions flash. The light comes on when I disconnect the EGR.
Old Aug 2, 2004 | 04:23 PM
fordsd's Avatar
fordsd
Wink No Light
Have an 01/04 engine build date bought in Kent Washington. No Light. Am anxiously awaiting my Predator to check for codes.
Old Aug 2, 2004 | 08:44 PM
ninelives 59's Avatar
ninelives 59
no check engine light for me build 3/03
Old Aug 2, 2004 | 10:23 PM
jdadamsjr's Avatar
jdadamsjr
fordsd - you WILL have egr codes... but they don't effect the performance - have had my egr disconnected for about a month now with no ill effects...
Old Aug 3, 2004 | 11:09 AM
fordsd's Avatar
fordsd
Question EGR codes
I assume that clearing it with the predator will only last until the next start. So I will need to clear the codes and install the original program before dealer service?
Old Aug 3, 2004 | 12:11 PM
jdadamsjr's Avatar
jdadamsjr
Oh, by all means...
You should ALWAYS reconnect egr, restore stock program, and clear codes (in that order) before service --- ALWAYS !
And clear codes once more after going back to stock to ensure they ARE cleared...
you don't want the dealer install a new flash and then it doesn't match your predator stored original flash...
your predator would stop working with your truck,
you'd be driving a stock truck,
and you'd probably be red flagged and lose your ford warranty...
but other than that - it's up to you
Old Aug 3, 2004 | 02:47 PM
SBV45's Avatar
SBV45
And do it a couple days before you take it to the dealer. I did that the last time and sat in the street outside the dealer and reloaded the 65HP program after I left.
clevelandjim
Feb 21, 2005 08:04 AM
dcale101
1983 - 2012 Ranger & B-Series
30
Nov 19, 2004 06:05 PM
MetallicaFan39
Jun 1, 2004 08:47 PM
seumas
Sep 10, 2003 10:49 AM
desperado
Jan 16, 2003 11:55 AM
