I would recomend giving Truxedo soft covers a good look. I had a regular Truxedo on my 01 Supercrew and just put a Truxedo Low Profile on my 04 Supercrew. Totally satisfied. Truxedo has a great website for info. and if you type in Truxedo on ebay there are several dealers selling there and you can pick one up for well under $400. Several good manufacturers out there, however, based on my experience I am confident you will be happy with a Truxedo.
I have the Access Limited and think it's great. I do not have experience with any other roll up snap-less, but I really didn't look around much. Access had what I wanted and I personally preferred the Access method of tensioning adjustemnt.
Surplusequipment.com has Access Limited for $445 shipped. I got mine at a better price since I did an Access Cover/Bedrug/TrailSeal combo.
Good luck though...I hear a lot of good about both Access & Truxedo
I went with the access and like it alot. I think I paid around $360. Bought it off the internet. I would buy locally if they were close in price.I would rather see my money spent locally then mail ordering, but local dealers wouldn't budge on price.($450-$500)
Just my 2 cents.
I don't hear anything - even with the rear slider open. Maybe the tension adjustment? I followed the procedures carefully, INCLUDING using the scale. Just a thought.
I purchased a Lund Genisis Hinged cover for my 04 Lariat Screw. Pictures are avail in my gallery. Very happy with it. Picked it up for under 300 bucks on the web.
If you get one, make sure you use the extra braces for the front rail. You will see them in the box as a seperate item with instructions for their use.
I really like my Access cover. Got it locally for $399, a bit more than I found it online but I'm with samia, I like to do business with the local shops. Plus I got the instant gratification. I used the scale too when I installed it. Doesn't make a sound when I'm on the highway so maybe it is the tension adjustment.
Les017,
Thanks for the tip about the scales. I had it installed by a local dealer and I went out and shecked it after reading the info over. It only had 20 lbs of tension. I've adjusted it and I'll know soon. Hopefully that will fix my noise. Thanks!
I bought an Access cover for my Screw locally for $389. I really like the ease in which is rolls up and stores. It does let a little more water into the bed while driving in rain than the Sportmasters I had on my '97 but the snaps on the Sportmasters was a pain. Has anyone put the tailgate seal on that's available from Access? $29 seamed a little high to me. Also, I've never noticed any noise coming from the cover, although you can see it moving quite a bit at highway speeds.
In case anyone else reads this post and worries about the noise. I totally uninstalled and then reinstalled the Access cover asnd the noise problem is gone. My dealer made quite a few install errors and I suppose I should have done myself the first time. The cover is now good, and quiet.
I've had my Access limited cover for about a year and a half now on my F-250 V10. I'm delighted with it ! The ease of having the cover stays roll up with the cover and having full access to the bed of my truck for tall "stuff" tells me I made the right choice. I bought mine locally and it was the dealer's first install. I ended up uninstalling and reinstalling myself to get it lined up perfectly. The written instructions with the cover are a bit lacking but the photos on the instruction sheet pretty much make installing it a snap I'd estimate about a 2 hour or less install. I do recommend, though, a thin strip of foam sealer tape between the front of the bed and the metal tensioning strip of the cover to keep out rain. Mine leaks a little at that point but none on the sides or back.
