Temp guage problem '64 + steering update
Old Aug 2, 2004 | 08:05 AM
grdf100's Avatar
grdf100
I don't see my temp guage registering proper temp. I grounded out the wire from the sending unit and the guage moved to about 3/4 pegged. Replaced sending unit. Still no movement. What is normal operating temp of the 223?
As to my steering wheel adjustment I adjusted the column up to a presentable tollerence but noticed shifting smoothness had deteriorated so I let the column fall backto original position. Will continue to fuss with it a bit today.
So glad I found this forum. The responces have been great and ther is a world of info here - especially for a non gear-head like myself. Thanks Guys.
Old Aug 2, 2004 | 02:31 PM
barry's Avatar
barry
If you grounded it and it didn't go all the way up, the guage is lazy or bad. Did you replace the constant voltage regulator behind the dash? You can get them thru NAPA. Those regulate a constant 6V to the guage. Usually when they go bad, all the guages will "spike" on and off. If your guages are acting fine and just the temp guage is acting up, I'd replace it, Make sure your bushings in your shift levers, tranny levers are good. They will wear into a particular spot and if you raise the column jacket as you did, they are now out of that wear pattern and will bind on you. The lower socket where the shift rods connect to the levers there also will wear. As I remember it's aluminum and will wear.
Barry
Old Aug 2, 2004 | 06:38 PM
bookwalter04stx's Avatar
bookwalter04stx
you didnt put teflon tape on your sending unit did you? this will cancel the ground.
Old Aug 2, 2004 | 09:10 PM
RaleighDad66's Avatar
RaleighDad66
Teflon tape does not cancel the ground. The pipe threads are much stronger and cut through the tape so there is metal to metal contact. The tape acts both as a lubricant to seat the threads further and to act as a void filler.
Old Aug 4, 2004 | 06:23 PM
bookwalter04stx
teflon tape most certainly does cancel the ground on sending units. i have a 65 mustang that proved this point to me.
Thumper47
1983 - 2012 Ranger & B-Series
Mar 27, 2013 04:51 PM
whiskeyrichard
Aug 21, 2008 01:43 PM
priv8pilot
Jul 20, 2006 10:36 AM
Josh79
Electrical Systems/Wiring
Jun 15, 2004 11:18 AM
Flood
Apr 18, 2004 08:37 PM
