Transmission Question
Old Aug 1, 2004 | 09:54 PM
1979meangreen's Avatar
1979meangreen
I have a 1979 ford F-150 4WD with a big block C-6 with a NP205 transfer case. My problem it that my tranny is shot. I have a small block 4 WD C-6 and a big block 2WD C-6 laying around. I need to know if the internal parts of the small block 4 WD C-6 will swap out or will the NP205 bolt up if i remove the tailshaft of the big block 2WD C-6. If this, or any other way will work, please let me know.
Old Aug 2, 2004 | 09:08 AM
mark a.'s Avatar
mark a.
The internal parts will interchange. The 2 wd. trans wont swap in, the tail shaft would have to be changed. Also 4 wd C6 came in 2 different tail shaft lengths if you find a used one make sure you have the right length.
dig'umz
Feb 28, 2013 08:01 PM
lisagoud
Sep 19, 2011 03:49 PM
78_f150
Nov 16, 2010 03:49 PM
46willys
Sep 11, 2007 12:26 PM
rsalter66
1978 - 1996 Big Bronco
Sep 4, 2007 11:23 PM
