351W c6Tranny issue HELP??
Old Feb 16, 2013 | 09:08 PM
dig'umz's Avatar
dig'umz
Ok...sooo My c6 Auto tranny Wont shift out of park...
i can get out and manually shift it. and feel and hear the AT Shift linkage click into each Gear but wont engage and drive off the driveway. i got Vacuum i got The correct Fluid levels and etc [ Standard do it yourself maintenance]
i bought the tranny from a friend.. it worked before i put it in.. but heres what i did
first off.
i yanked a 400m 6.6L with C6 Big block Bell housing auto trans With a NP205 Part time Transfercase out of my 1979 F-150 4x4 Truck everything but the motor worked PERFECT. before i pulled it. .
Dropped in a 1979 351Windsor with a C6 Small block bell housing Changed the Transfercase Adapter from the 400m C6 to the 351w C6 installed the NP205 Transfercase on the Small Block C6- [Fit like new]
Now when i installed the TC to the Flexplate they were the same color TC im wondering if theres a Difference in TC's Compaired the The BIG Block C6 Bellhoused Tranny to the Small block c6 Bellhoused Tranny..
If there is then thats my issue
any advise where to start would be MOST helpful. its been a hard first build for me. and im willing to learn more. Thank you!
Old Feb 16, 2013 | 10:51 PM
xkpsanit's Avatar
xkpsanit
Same color converter??? I swear i used the same converter in my baby c6 swap. Does it grind into park when you're trying to get it to move? Is the t case engaged? You could check that by spinning the rear output shaft with the tranny in park. In should be locked with only minimal lash. If it spins freely, case probs or tranny output to case input shaft.
Old Feb 17, 2013 | 05:58 AM
BigBlockMan's Avatar
BigBlockMan
I think the difference in the BB and SBF TC is the flywheel bolt pattern. I think the problem may be here-
The transmission may be turning but not the transfer case.
Old Feb 17, 2013 | 09:08 AM
xkpsanit's Avatar
xkpsanit
This was the reason i asked if it ground into park. No load to stop the tranny from spinning, and in turn rattle on the park pin.
Old Feb 17, 2013 | 09:57 AM
dig'umz's Avatar
dig'umz
i Think the tail housing and tailshafts are the same dont understand why the NP205 Transfercase wouldnt work with the SB C6
as for the output shaft.. it goes in park. but not in gear. moves free.
shifting from inside the truck. theres no Griding or clicking or anything i dont even feel the Transfercase jerk into gear. its like its stuck in neutral
like. i used to have to be in park to get the T case into 4H i can freely move the 4x4 Shifter and the Column shifter.. theres no resistance or anything.
anychance i could talk to someone over the phone?
Old Feb 17, 2013 | 01:26 PM
dig'umz's Avatar
dig'umz
ok soo update... i unbolted the TC bolts started the truck put it in park it started clicking like it wasnt catching gear or the 4x4 wasnt in 2wheel...... could it just be the Torque converter not engaging the Tranny pump ?
Old Feb 17, 2013 | 02:54 PM
xkpsanit's Avatar
xkpsanit
That would be your park pin. This is normal, as if your t case was in neutral (no load on the output shaft of tranny) What did this tranny come out of? Does it have a 4x4 output shaft?
Old Feb 17, 2013 | 03:33 PM
dig'umz's Avatar
dig'umz
well i pulled the tranny today the TC aint even in the grooves for the Tranny pump... now im trying to figure out how to take off the 7bolt plate inside the bellhousing to replace it.
Old Feb 17, 2013 | 03:46 PM
xkpsanit's Avatar
xkpsanit
Ok, didnt forsee that. The ? is why isnt it engaging? This is not an odd application. Maybe it is the wrong TC.
Old Feb 17, 2013 | 04:30 PM
dig'umz's Avatar
dig'umz
i swapped TC's ill see if it works.. and update it from there... could be a bad pump gear that the TC slides into.. i hope not
Old Feb 17, 2013 | 06:31 PM
dig'umz's Avatar
dig'umz
well the TC Fit.. as for it working idk the starter wont turn the flywheel and everything over... any ideas? all the starter does is slip into the flywheel groves and click.
Old Feb 28, 2013 | 08:01 PM
xkpsanit's Avatar
xkpsanit
Did you get this resolved??
Chris Guthro
Jun 18, 2020 10:12 AM
Larry5501
Dec 23, 2017 10:02 AM
onefifth
Jul 16, 2012 11:25 AM
angelblue23
Mar 7, 2009 10:55 PM
torme
Jan 20, 2005 07:07 PM
