Desktop Dyno again
Old Aug 1, 2004 | 06:09 PM
FERacing66's Avatar
FERacing66
Desktop Dyno again
Got another dd question here. Could you run desktop dyno for this setup:
66 352
Crane 901
Edel peformer intake
holley 600cfm vacum secondary
hedman headers
Thanks in advance
Old Aug 1, 2004 | 06:12 PM
Ratsmoker's Avatar
Ratsmoker
Need to know compression, and head casting number. It is between the spark plugs on the heads.
Old Aug 1, 2004 | 10:29 PM
FERacing66's Avatar
FERacing66
okay thanks ill check in the morning.
Old Aug 2, 2004 | 09:30 AM
FERacing66's Avatar
FERacing66
the head casting number is
C6AE-R
I dont know what the comperssion is on this engine. Is there anyway to tell? It is currently toren down to the block on the engine stand.
Old Aug 2, 2004 | 06:37 PM
FERacing66's Avatar
FERacing66
Does anyone know where I can get desktop dyno for the best price.
Old Aug 2, 2004 | 07:11 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
66, The last time I was at wally world...they han them in the Video dept. for $39.99
Old Aug 2, 2004 | 09:56 PM
FERacing66's Avatar
FERacing66
Darn I really wanted to get the HP and Torqe numbers for my buildup.
Old Aug 2, 2004 | 10:48 PM
fordeverpower's Avatar
fordeverpower
i broke down and got dynosim with pro tools. Works great! they say within 5% accuracy. if you can the right head flow and select the correct numbers i find it pretty close. now if i can learn how to get the graph on the forums i will be set.
Old Aug 2, 2004 | 11:38 PM
fordeverpower
for now!
HP TQ
1000 59 311
1500 104 364
2000 149 392
2500 187 393
3000 224 393
3500 267 401
4000 289 380
4500 295 344
5000 278 292
5500 246 235
6000 204 179
Hopefully i can get the uploading figured out soon! Btw I used 2.9 lifter accel, 9.3 comp ratio, headers with mufflers, and c8ae flow data.
Old Aug 3, 2004 | 09:30 AM
RapidRuss's Avatar
RapidRuss
Well 66, I ran it on the DD2, with your Specs, Cam timming at .004"
With 9.5 to 1 CR..
383lbs of torque @ 3500rpm
297HP @4500rpm
Good luck on your build..Russ
Old Aug 3, 2004 | 11:19 AM
Ratsmoker's Avatar
Ratsmoker
I don't have any flow data for the C6 heads. Does anybody else? The C8 should be close though.
Old Aug 3, 2004 | 11:27 AM
RapidRuss's Avatar
RapidRuss
Sean, I didnt use any flow data, I just used Valve size,and carb flow? and cam at .004" specs?
Old Aug 3, 2004 | 12:30 PM
FORD352V8's Avatar
FORD352V8
Alright thanks I think Ill be happy with the pefromace. Thanks a bunch guys.
Old Aug 3, 2004 | 02:45 PM
FORD352V8's Avatar
FORD352V8
ARRRRRGH! Someone has broken into my account! I did not post that last post. Im gonna change the password.
tjc transport
New Jersey Chapter
Feb 27, 2007 05:10 PM
moore89
13
Mar 24, 2004 12:55 PM
JD466
Jan 1, 2002 06:28 PM
