Help 97 ranger 4.0 engine code P1443
Old Jul 30, 2004 | 09:28 AM
woody1003's Avatar
woody1003
I have a 97 4.0 ranger, and check engine light is comming on. It is a code P1443 the person that checked it from me says it is a dealer code and didn't know what it was. I have had it checked out once before by my mechanic and he said it is an Evap emissions code but didn't have a "smoke tester" (whatever that is) to find the problem. I have had the EGR valve replaced by the dealer and this light came on about 3 months later. There is also a sensor between canister and engine on the vacume line is there a way of testing this? Also vac lines look a bit dry is it worth changing the vac lines. Thanks for any help.
Old Jul 30, 2004 | 05:49 PM
hreed's Avatar
hreed
It's probably the purge control valve or the thermistor. I changed both on mine and the light went away. It could also be a bad vacuum hose or the canister may have failed, but probably the valve. You need a vacuum pump to test the system.
Old Jul 31, 2004 | 08:34 AM
rebocardo's Avatar
rebocardo
I did a Taurus recently that had that code and found the switch connector was loose/off and the vehicle had various vacuum leaks, especially near the back of the manifold. I would replace all the rubber lines and make sure the hard plastic lines are intact. After securing the connector and replacing the lines and clearing the code, the vehicle was fine.
Old Jul 31, 2004 | 09:57 AM
Rockledge's Avatar
Rockledge
Welcome to FTE!
The 3.0L and 4.0L EVAP systems operate the same way, this is a thread that is relevant to your issue:
https://www.ford-trucks.com/forums/s...hreadid=152825
Old Aug 2, 2004 | 10:25 AM
woody1003's Avatar
woody1003
Smile Thanks
Thanks all for the help!!! That was a good thread the ford part F57Z-9C87-BA Canister Purge Solenoid/Flow Sensor
Assembly - 4.0L fixed it. I am a new member I will do some reaserch next time before I do a PANIC POST
Thanks Again
Old Aug 2, 2004 | 10:40 AM
Rockledge's Avatar
Rockledge
Occasional panic post = par for the course (your's is not that bad, trust me )
Glad to hear you fixed the problem.
LISTEN
Aerostar
Apr 17, 2017 01:36 PM
Supercab
Apr 25, 2011 09:28 AM
juggshunter
15
Nov 16, 2005 09:16 PM
Roguespirit
Oct 10, 2003 12:00 AM
macwho
Aerostar
Aug 26, 2002 08:54 PM
