Power Steering Fluid Leaking 2000 B3000
Old Jul 27, 2004 | 03:33 PM
jeffomaclean's Avatar
jeffomaclean
I noticed 2 days ago that my truck was making lots of noise while turning, I topped up the fluid for the power steering and the noise went away. I have looked under the truck and there is a significant amt. of fluid behind the rad and looks as though it may be coming from the steel lines connected to a metal box near the front. Any suggestions. Thank you in advance.
Old Jul 27, 2004 | 05:06 PM
Dave257's Avatar
Dave257
Sounds like a leak in the line going/comming from the power steering cooler.
Dave
Old Jul 27, 2004 | 05:11 PM
ejpreston's Avatar
ejpreston
Have someone turn the wheel whith the truck on as you look around. There's a lot of pressure going through those lines when the wheel turns so any leaks should begin really leaking when the wheel is cranked. Just wear eye protection and stay back at first (not that I know from experience or anything) and you should find the source of your leak.
Old Jul 27, 2004 | 06:03 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
Old Jul 27, 2004 | 06:50 PM
jeffomaclean
I will have someone turn the wheel as I look. Thanks ejpreston, I will let you know how it turns out.
Old Jul 29, 2004 | 10:26 AM
Critterhunter's Avatar
Critterhunter
The most common leak is the lower seal on the pitman arm shaft. Refer back a few weeks and you'll find a post on how I replaced mine if it turns out to be leaking. Pretty easy.
CountryMonkey07
Nov 20, 2015 07:18 PM
t24021994
May 24, 2015 12:50 AM
pdrunk
Feb 11, 2015 09:26 PM
Smith76
Mar 8, 2006 09:11 AM
SDJERSEY
Aug 7, 2004 07:52 AM
