General Automotive Discussion
Oil level on Dipstick
Old Jul 27, 2004 | 03:01 PM
jherman's Avatar
jherman
I have a F259 1972 with 390. I have always keep the oil at the full mark when cold. I recently changed oil, put 5 qts in, ran the engine, let sit overnight, and checked oil level. Level was 1/2 way between the add and full marks on the dipstick. So, is the consensus, I should leave it at that level and consider that being all the oil it should have, or add 1/2 quart and bring it to the "full" mark?
What kind of damage can 1/2qt, 1qt, or 1 1/2 qt too full, if any, do to an engine?
Joe
Old Jul 27, 2004 | 03:04 PM
fellro86's Avatar
fellro86
i would say leave it, as thet is the zone which the manufacturer decided is safe to run, no higher and no lower, although you can get away with a little either way, just that in the hash marks is acceptable.
Old Jul 27, 2004 | 06:20 PM
baitmaster's Avatar
baitmaster
When I first got my 72 F100 with 390 in it, it had 2 dipsticks, one thru the block, and 1 thru the pan. Never knew which one to believe. Some one had bolted on an 8 or 9 qt pan. So when I did my rebuild, I got rid of pan stick, and welded hole shut. It took 9 qt of water in pan to get it to just below crank level. (Off the block of course). Then after motor went together, I installed new dipstick and 9 qt of oil, and then ground a new hash mark on bottom of stick. By the way, I have always kept my oil level at "Full" mark, rather than leave it at 1/2 qt low. Just the way I am.
Old Jul 27, 2004 | 10:24 PM
memorylanetrucks's Avatar
memorylanetrucks
I thought all the truck (pickup) FE motors took 6 quarts.... that's what a Ford parts counterman told me, and I thought I read it somewhere on this site, too.
Old Jul 28, 2004 | 09:49 AM
jherman's Avatar
jherman
1972 F250 390 oil capacity
Prior to the oil change I looked up the engine oil capacity in the 1972 factory manual and it said 5 quarts for the 390. I will probably look in the owners manual tonight to see if there is any discrepancy. So what I was saying in the first post was after running the engine a few minutes and letting the oil settle overnight the "full" mark was 1/2 way between add and full on the dipstick. It goes without saying I put a new oil filter in. The oil filter mounts horizontally but it still holds some oil. I wouldn't be surprised if it holds about 1/2 quart which would explain why the level is down by 1/2 quart on the dip stick. If that is true, and the oil filter is holding at least 1/2 quart would it make sense to add another 1/2 quart or consider your full level to be the middle point between add and full on the dipstick?
It will probably turn out it doesn't make any difference.
Thanks.
Joe
Old Jul 28, 2004 | 06:00 PM
baitmaster's Avatar
baitmaster
BTW, when I change oil, I always fill filter about half full before screwing it on. On a filter that is mounted straight up, I will fill it to the top. You will notice the engine runs quieter in the first few seconds of first start-up. (Less noise, less wear)
Old Jul 28, 2004 | 06:31 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
baitmaster, if you run a 3 quart accumulator, thats 1 1/2 qt. oil and 1 1/2 qt. precharge you'll have a "wet start" before the crank turns after doing a oil change.
(no lifter, bearing noise, minimal wear)............................o&o>............. .................
Old Jul 28, 2004 | 10:43 PM
4020loaderman's Avatar
4020loaderman
i have a 94 ranger that ever since i bought it i noticed that at 2/3's the way to full line is where it would always run and if i added to put it on the full line in 3 days or so it would drop back down to the 2/3's level so i just leave it there because it rarely drops to where i need to add a little. In short just use your own judgement, try to find out where it seams like it is full to you. Also after you change oil, run the engine for 2 or 3 min. turn it off after about 5 or 10 min check the oil, it may need a little oil due to the filter. after that just use common sence when you check oil
Old Jul 29, 2004 | 11:06 AM
jherman's Avatar
jherman
Baitmaster,
Thanks. Good tip.
Joe
Old Jul 29, 2004 | 08:18 PM
baitmaster's Avatar
baitmaster
Beemer, you are so right, but right now I've got a full power steering kit, oil cooler kit, 1 wire alt, and poly spring bushings sitting in a pile on the garage floor. One project at a time... if I could only find some time.
Old Jul 29, 2004 | 10:45 PM
"Beemer Nut"
baitmaster, it's summer you should be on the road, save the repairs for winter. The new
ford trucks, 98 up have a power steering cooler under the front bumper, works better than the old loop tube coolers on the bumpsides and it's easy to mount.
Part # F81A-3D746-AC. 4" x 6" x 3/4", has mounting brackets, cost only 42 clams. It can mount to 1 1/4" angle iron across the frame rails. You'll have to hard pipe from the steering box to cooler and to the pump with a short flexable hose to the pump return. Try Neo power steering oil verse ATF. My $.02. Carl..........................o&o>............
Old Jul 30, 2004 | 12:13 AM
FSC's Avatar
FSC
As long as the oil level is between the add and full marks, it is fine, a little over or under won't cause any harm.
Old Jul 30, 2004 | 02:07 AM
"Beemer Nut"
FSC, is your running a FT sump, that can take 13 1/2 quarts of oil,you should not over fill with the standard oil filter dipstick as you may cause foam or bubbles from the crank whipping the oil, bad thing unless you have a windage tray, flanges and trap doors. Over filling can be worse than under filling. If your going to drag of go off road you want rear sump pickup with full sump. This way if the engine fails it's not by lack of lubrication. Too much is as bad as too little lube.......................o&o>................... .
Old Jul 30, 2004 | 09:37 AM
mikeh98's Avatar
mikeh98
Another thing to consider is that something may be keeping some oil in the top of the engine, a plugged oil return hole or such or it could be that there is something keeping the dipstick from seating properly in the tube. Seems odd that it is now just a little low. Consensus should be that if it is between the marks don't do anything and too much is bad.
JNG6
15
Feb 15, 2014 12:27 PM
Bananarama
2011 - 2019 Explorer
Aug 15, 2013 10:19 AM
1saxman
2004 - 2008 F150
Nov 16, 2010 08:30 PM
trakman
Jan 26, 2005 05:22 AM
Mathwiz
2004 - 2008 F150
Nov 10, 2004 01:06 PM
