TorqueShift Max Torque?
Old Jul 26, 2004 | 11:38 PM
skyhook8's Avatar
skyhook8
I'm about to purchase a Duramax but the maximum torque that the stock Allison will handle is around 700 ft/lbs. After that you have to pull the transmission and add a Transgo kit (~$300 self install) and possibly a torque convertor (~$1200).
What is the maximum torque that the stock TorqueShift transmission will handle? Also, what is the entry level upgrade to the transmission and how much additional torque will it handle? What is that cost?
Thanks for your help.
Old Jul 26, 2004 | 11:45 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Choctaw Bob has been running 728 ft-lbs on his truck for 22k miles now and has had no issues. I have taken mine with an SCMT, an exhaust system, and a water injection system ( never dynoed, but had to be in the high 700 to low 800 torque range) and launched it numerous times in 4x4 with no transmission issues to date (7600 miles)
Old Jul 27, 2004 | 07:41 AM
jdadamsjr's Avatar
jdadamsjr
Skyhook from your signature, sounds like u like to "tinker" with your trucks
All reports are that the TS can take a tremendous increase in lbft...
I have heard daily drivers in the high 800 lbft's...
mine with stock intake, Predator, and turbo back has been running in the 720 lbft since about March... and I promise you it gets "used"...
32K miles and not a whisper of a problem...
they got this torqueshift right !
The only change I would make to it ?
Upshift at lower rpms when not at full throttle....
and don't downshift when accelerating at anything less than 3/4 throttle...
let the 700lbft of torque WORK!
but that's a computer change - not a tranny change
Old Jul 27, 2004 | 08:15 PM
uponyou21's Avatar
uponyou21
if u are about to buy a duramax then u should'nt be in here this is for real trucks!!!
Old Jul 27, 2004 | 08:27 PM
SpartanDieselTech
Former Vendor
I loathe Chevrolet, but was that comment really needed?
Old Jul 27, 2004 | 10:02 PM
skyhook8's Avatar
skyhook8
I've received more information from other forums and from a vendor and it appears that the TorqueShift's adaptive shifting has trouble with the higher torque. I was also told that the upgrade options on the Torqueshift are limited.
As a side note, I test drove a Powerstroke with the LT 275x70x18 tires/wheels today. Very nice looking truck. The power was outstanding. I know the Duramax didn't leave the same impression on me.
I had thought that Ford was discounting as much or more than Chevrolet but now that I've looked into it more that doesn't appear to be the case. Since the diesels are pushing my budget to the limit it looks like I might be purchasing a Duramax.
Old Jul 27, 2004 | 10:07 PM
SpartanDieselTech
Former Vendor
Niether of those are true. After several cold starts and some logged miles (assuming you have a good chip/module/programmer) the transmission will adapt nearly perfectly to any given amount of torque that wont tear it apart. Also, both Suncoast and BTS offer full-blown Torqshift rebuilds, shift kits, and converters for just about any power application for the Torqshift.
Old Jul 27, 2004 | 10:10 PM
jdadamsjr's Avatar
jdadamsjr
ANY tranny will have issues with "higher torque"
but what is the definition of higher torque ?!?!?!!?!? you ask ?
the torque at which it is not designed to handle....
I KNOW the torqueshft will handle 800 ftlb's ......
and unless you're building a drag truck... that's MORE THAN enough !
Old Jul 27, 2004 | 10:41 PM
skyhook8's Avatar
skyhook8
Quote from an un-named, high profile vendor:
"The torque shift has a hard time adapting to the high hp anything up over 100hp due to its adaptive shift strategy. You can get the allison to break down in the high hp settings but overall the allison seems to handle the high hp better than the torque shift. One of the main advantages the allison has is the capablilty to upgrade with aftermarket parts there isn't alot available for the torque shift at this time. If your planning on running alot of power I would suggest the Allison with a few upgrades to the torque converter and some clutching until they come out with something to help the torque shift."
I don't see anything on the Suncoast or the BTC site about the Torqshift. They only mention the 4R100.
If I add a Transgo kit ($200 on Ebay) to the Allison I can run Edge Juice Level 5.
If I want to run Edge Juice Level 5 with the Torqshift what do I have to do to get it to last and to shift right?
Old Jul 27, 2004 | 10:48 PM
SpartanDieselTech
Former Vendor
I know for a fact it is on Suncoast's website. It is referred to as the 5R110. I could be wrong, but I can see Banks being the high-profile vendor to say that...
I'm not concerned about mine, personally. If it rips apart I have a spare, and that will give me a good core to send in for a rebuild.
The 5 setting on the Powerstroke Edge requires no transmission modifications. I confirmed this with Edge products before I ordered thier box from Beam Chevrolet in Forest City, NC. I pick mine up tomorrow, and the truck on Thursday.
Old Jul 27, 2004 | 11:28 PM
jdadamsjr's Avatar
jdadamsjr
Bet that un-named High profile vendor does not sell a High horsepower box then
What do the vendors that seel the 165 HP and 160 HP boxes say....
All I can tell you is that mine and Choctaw Bob's trannies don't have an issue... and you can look at our dyno charts....
Old Jul 28, 2004 | 05:07 AM
user 708242442's Avatar
user 708242442
Torqueshift is rated to 1175ft lbs of torque.I read it in my Powerstroke Registry.I'm looking for the issue now.
Old Jul 28, 2004 | 07:50 AM
jdadamsjr's Avatar
jdadamsjr
WAIT JUST ONE COTTON PICKIN MINUTE THERE KR !!!!!!!!!!
How can u just flippantly mention that and go on ?!?!?
A Powerstroke Registry ??? Is that a rag about our trucks ?
Hurry, tell me where to sign up !
Old Jul 28, 2004 | 07:59 AM
user 708242442
I'll e-mail you
Old Jul 28, 2004 | 08:02 AM
SBV45's Avatar
SBV45
Pretty hard to get to your C: drive from here. Got a web link?
