TorqueShift Max Torque?
Old Jul 28, 2004 | 08:04 AM
user 708242442's Avatar
user 708242442
I'm trying to get it up give me your e-mails
Old Jul 28, 2004 | 08:06 AM
user 708242442
http://www.powerstrokeregistry.com/
Old Jul 28, 2004 | 08:10 AM
user 708242442
Sorry about that I was having technical issues with my computer .
Old Jul 28, 2004 | 08:13 AM
jdadamsjr's Avatar
jdadamsjr
Thanks KR !
You're all right !
No matter WHAT Tim says
j/k
Old Jul 28, 2004 | 08:14 AM
user 708242442
I'm not sure I have the latest issue in my gallery under my new truck
Old Jul 28, 2004 | 08:27 AM
skyhook8's Avatar
skyhook8
The specification sheet for the Torqshift will give you the torque rating but that is [after] the torque convertor which multiplies the flywheel torque.
Old Jul 28, 2004 | 09:11 AM
Choctaw Bob's Avatar
Choctaw Bob
The general consensus of opinion on most of the technical forums is that the stock torqushift will handle 1,200 ft. lb. of torque in an empty truck.
A lot of the ideas you have gathered are simply wrong. Do a search on this Forum and some of the other technical forums and you will find the answer.
Multiplied torque to the transmission input and ourput shafts and all the clutches and gears in between is the torque the trans must be able to handle. You may be getting engine torque output and transmission load capability confused.
Old Jul 28, 2004 | 09:50 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by skyhook8
Quote from an un-named, high profile vendor:
"The torque shift has a hard time adapting to the high hp anything up over 100hp due to its adaptive shift strategy. You can get the allison to break down in the high hp settings but overall the allison seems to handle the high hp better than the torque shift. One of the main advantages the allison has is the capablilty to upgrade with aftermarket parts there isn't alot available for the torque shift at this time. If your planning on running alot of power I would suggest the Allison with a few upgrades to the torque converter and some clutching until they come out with something to help the torque shift."
I don't see anything on the Suncoast or the BTC site about the Torqshift. They only mention the 4R100.
If I add a Transgo kit ($200 on Ebay) to the Allison I can run Edge Juice Level 5.
If I want to run Edge Juice Level 5 with the Torqshift what do I have to do to get it to last and to shift right?
Name it, I would like to know
what do you do for a living...curious
Old Jul 28, 2004 | 10:17 AM
skyhook8's Avatar
skyhook8
This quote is from Gregg Evans (Factory Tech) in reference to the 4R100:
"It's rated for 1000 lb/ft at the geartrain, but the converter multiplies torque at a factro of 1:2.13, so safely about 500 lb/ft at the flywheel. The torque multiplication decreases as RPMs increase, it's hard to explain, but short answer is 500 pounds at the flywheel, give or take a few."
Old Jul 28, 2004 | 10:22 AM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
That is just downright wrong. No offense to you, but the source of that information is totally wrong. The basics of what he said are correct but the 4R100 WILL, and I mean ABSOLUTELY WILL handle ALOT more than 500 ft-lbs. My uncle has a 7.3 (525ft-lbs STOCK!) with a 125 horse, 240 ft-lb flip chip that he runs on full blast towing a concrete pump. He has a totally stock transmission that has 72,000 miles on it (and that was the last time I saw him, about a month ago) and not a single problem out of it. That is hooey.
Old Jul 28, 2004 | 10:26 AM
skyhook8's Avatar
skyhook8
Originally Posted by Tim Lamkin
Name it
I'd have to get permission from the source to name it. If you want I'll ask but they do a lot (I'm guessing) of business with Ford owners and since he seems to give an advantage to the Allison I didn't feel it would be considerate to him to make his private message public. Of course, this was one person's response and the official statement from the company would most likely be much more balanced.
I would like to know what do you do for a living...curious
I'm definitely not in the automotive business if that's what you're getting to. I'm just a guy that likes to go faster than the next while spending as little money and time as possible.
Old Jul 28, 2004 | 10:52 AM
skyhook8's Avatar
skyhook8
Originally Posted by PSD 60L Fx4
the source of that information is totally wrong... That is hooey.
You can check that souce. Gregg is probably the most knowledgable person on the planet when it comes to the 4R100.
Now my statement [is] rather extreme but you'll find that you won't be able to argue with it.
Old Jul 28, 2004 | 11:49 AM
  #28
IB Tim's Avatar
IB Tim
so no part of what you do is tied to the auto industry
Old Jul 28, 2004 | 11:55 AM
  #29
skyhook8's Avatar
skyhook8
I'm a systems engineer for an online dating company.
Old Jul 28, 2004 | 12:26 PM
  #30
mattsf250's Avatar
mattsf250
ooo oo, hook a brother up!
i like long walks on the beach, candlelight dinners...large breas....... ohh, systems engineer..... dad gummit! thought i was gonna get a discount or something.
not that my wife would approve, but hey, it is worth a shot.
