Diagnostics code 401, please help !
Old Jul 26, 2004 | 06:44 AM
99pickup's Avatar
99pickup
Question Diagnostics code 401, please help !
HI there
I'm a newbie to the forum and actually have a 1999 Mazda Troy Lee addition with the 3.0 V6 (Ford built as I am sure you already know !)
Anyway I am getting a Code PO401 - EGR restrictive Flow.
I am wondering if this is actually a problem with the EGR valve or if it could possibly be the EGR pressure Sensor. Any help is appreciated !
A little more info. I can clear the code and it will take about 25 - 30 min. of driving before it will return.
Thanks
Old Jul 26, 2004 | 07:23 AM
Bart99GT's Avatar
Bart99GT
Typically the EGR valve is off before the engine warms up, given the fact it takes a while for the code to appear, I'd try the EGR valve first.
Old Jul 26, 2004 | 07:43 AM
Rockledge's Avatar
Rockledge
Common code on the 3.0L, which is why my vote would be the "EGR pressure Sensor", which is more commonly known as the Differential Pressure Feedback EGR (DPFE) sensor. They tend to fail after a few years. Here are a few relevant links:
Ford DPFE/EGR System Summary
DPFE Vacuum & Voltage Test
P.S. Welcome to FTE!
Old Jul 26, 2004 | 09:12 AM
Vin 95's Avatar
Vin 95
When you remove the EGR valve,under it you will find a finger sized hole,at the BOTTOM of this is a SMALL port that needs to be poked out with a stiff piece of wire then a pipe cleaner.this port being clogged will cause a 401 code.
Old Jul 26, 2004 | 12:51 PM
99pickup's Avatar
99pickup
Thumbs up Thanks for the advice !!
I appreciate everyones input.
Still not sure which one to try first EGR or the sensor.
But did give me a few ideas to look at.
I'll look everything over real good this evening and see if it is something obvious
and then try and make a desision then.
Old Jul 26, 2004 | 01:01 PM
Rockledge's Avatar
Rockledge
Why not do it in sequence ...remove the EGR valve and clean out the port (good suggestion), clear the code, and then drive around and see if the code comes back. So far, no $ spent.
Then, if the code comes back, I think you can be pretty sure its the DPFE.
Old Jul 27, 2004 | 08:21 AM
pawpaw's Avatar
pawpaw
I like the ideas Vin95 & Rockledge posted, at least you'll know the EGR & it's troublesome port will be clean & all that will cost is a little time & effort.
As Rockledge said, if cleaning the EGR doesn't do it, then suspect the DPFE, now replacing that will cost you some gold.
Pick up a Haynes manual for your ride at your local autoparts store or check one out at the library. It has several tests, mechanical & electrical, you can perform on the DPFE to see if it's electrically & mechanically doing it's thing, or getting the proper signal from the computer to operate the EGR properly.
The computer takes it's ques from other sensors like coolant temp, MAF, ect, ect to tell the DPFE when to turn the EGR on & for how long, so inputs from these other sensors also have to be considered in troubleshooting.
Take your time, don't just begin throwing parts at the problem & hope to get lucky.
Let us know how it goes.
Old Jul 27, 2004 | 09:03 AM
99pickup's Avatar
99pickup
Still no luck !!
Ok, I pulled the EGR and cleaned it. Still got the code after about 20 mins of driving. I then pulled the Egr pressure sensor and cleaned it as was mentioned and replaced the hoses, no luck there either. Guess next step is a new sensor, only place I can find one is the dealer ...$68.55 whew!!
I sure hope that fixes it !!
Old Jul 27, 2004 | 09:07 AM
99pickup's Avatar
99pickup
This Small port you are refering to is actually located on the underside of the EGR valve itself correct ? Where the tube threads in to it.
Old Jul 27, 2004 | 09:30 AM
Vin 95's Avatar
Vin 95
No, Its at the bottom of the hole that the EGR covers in the intake manifold.
Old Jul 27, 2004 | 09:36 AM
pawpaw's Avatar
pawpaw
Ok 99Pickup, the DPFE solnoid resistance values should fall between 30 & 70 ohms.
Check your battery voltage to be shure it's up to snuff, then pull the DPFE electrical connector & measure the incoming voltage from the computer with KOEO, (Key ON Engine Off), VREF should be between 4 & 6 volts. If not, look up stream to the PCM, or your battery voltage is low.
There are also some electrical/mechanical tests to see if your DPFE is functioning properly.
Old Jul 27, 2004 | 10:28 AM
Rockledge's Avatar
Rockledge
Don't forget to clear the code before you test whether a repair works or not...
Old Jul 27, 2004 | 11:12 AM
99pickup's Avatar
99pickup
Ok, I am lost here ! THe EGR on my motor bolts to the manifold with 2 bolts (where the gasket is) and then has a tube that threads into the bottom of the EGR valve. From the EGR valve the tube takes a 90 on back towards the fire wall and has 2 smaller tubes coming off of it. THese 2 smaller tubes have rubber hose that goes to the EGR pressure sensor. With the EGR valve off and looking down into the tube all I see is a hollow tube. Looking at where it bolts to the manifold I just see an open hole.
If I am reading correctly then the Small hole is back up inside the hole where the EGR bolts to the manifold (2 bolts and gasket) correct ?
I'll have to pull it off and look up in there again ...I must have missed it or mine isn't the same.
Old Jul 27, 2004 | 11:31 AM
Vin 95's Avatar
Vin 95
Yes! your on to it. the small hole is back up inside the hole where the EGR bolts to the manifold.you'll need a STIFF peice of wire to poke it out. bailing wire works well,and a coathanger might go through but it would be tight.once you get a peice of wire to go through the port,ream it on out with a pipe cleaner or two.
Old Jul 27, 2004 | 02:04 PM
99pickup's Avatar
99pickup
Ok, cool.....I appreciate your patients !!! As well as everyones help !!
THanks again
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
kaw753
1997 - 2003 F150
Apr 15, 2011 12:54 AM
treehugger1
1997 - 2003 F150
Sep 4, 2010 09:10 AM
Nitrous
Aug 19, 2007 11:59 PM
btacroft1
36
Dec 29, 2003 06:24 PM
