Fuel Injectors?
Old Jul 25, 2004 | 09:12 PM
Mr.JP's Avatar
Mr.JP
Fuel Injectors?
I have never had to do this yet, but what all do i have to do when replacing the fuel injectors on my 95 inline 6 (4.9) Is it simple as unhooking the clip and unscrewing the injectors. Or is there something else i need to know before doing this?
Old Jul 25, 2004 | 09:17 PM
PyroBandito's Avatar
PyroBandito
I'm not sure about unscrewing them, the ones I've seen, you unbolt the fuel rail and pull it off and the injectors simply pull out. Atleast thats how it is on my V8. One thing you should know, though, is that they cost about 50 bucks apiece!
Old Jul 25, 2004 | 09:19 PM
Mr.JP's Avatar
Mr.JP
Yeah I found that out, I think im going to try and use an ohm meter and see if i cant figure which one is messing up. You have any take on this?
Old Jul 25, 2004 | 09:20 PM
c_rossman's Avatar
c_rossman
Just pull the upper intake off and remove the fuel rail. They just float in Oring, so just pull them out. You can get aftermarket ones for alot less $14-$15 a piece. I would recommend 19lb injectors and an adjustable fuel regulator, these are stock mustang size and easy to find.
Old Jul 25, 2004 | 09:24 PM
Mr.JP's Avatar
Mr.JP
Would i need anything else? 19lb fuel injectors and an adjustable fuel regulator?? This going on a Pickup f-150. I was courious if I could go with a bigger injector and get a little more power.
Old Jul 25, 2004 | 09:28 PM
c_rossman's Avatar
c_rossman
http://www.bigblocksix.com/Eddie/injectorswap/ Very good article about why you should upgrade, I did it on my 300 and drivabilty went thru the roof.
Old Jul 25, 2004 | 09:38 PM
Mr.JP's Avatar
Mr.JP
what was the cost of doing this? The artical is very good. Did you run into any problems?
Old Jul 26, 2004 | 05:31 PM
c_rossman's Avatar
c_rossman
The hardest part is modifing the Fuel regulator to work right, I bought a set of 8 mustang take off's off of Ebay for $50 for a set of 8, also the regulator was $40. With gaskets it cost me a $100. I didnt put a guage on mine, I just set my pressure at 40psi and it ran great.
Old Jul 28, 2004 | 07:20 PM
Mr.JP's Avatar
Mr.JP
Ok, well I have all the injectors out. I tested each one with a OHM meter and everyone is at 14.7. So is there a way to test them now that there out? What are my alternatives?
Old Jul 28, 2004 | 11:43 PM
LxMan1's Avatar
LxMan1
Without a testing machine, it would be difficult to put 40psi of fuel pressure thru them and watch the spray pattern.
Old Jul 28, 2004 | 11:46 PM
Mr.JP's Avatar
Mr.JP
So do you think I would be better off replacing all of them?
Old Jul 29, 2004 | 01:18 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Mr.JP; go to google and type in JectorRate then open the listing by Bowling and Grippo. You must do flow amount as well as spray pattern after the injectors are cleaned. If the injectors come out "matched set" and the engine is in good mechanical health it will surprise you how smooth it'll run. Check out, www.injectors4U.com or www.cruzinperformance.com. Had friends that used injectors4U, very satisfied customers. I assembled a JectorRate pulser, it works great and you can test your own injectors. Hope this helps, Carl. ........................................o&o>...... ..............
Old Aug 2, 2004 | 10:08 PM
Mr.JP's Avatar
Mr.JP
Thanks Beemernut, They are the cheapest that i have found. Now i just have to get ahold of them. They havent returned any emails. <injectorsforU>
chromehorn
Apr 29, 2015 01:01 AM
96_F250_Deezal
Mar 18, 2014 09:30 PM
RobbyMartin
1997 - 2003 F150
Feb 14, 2010 08:42 PM
kevbits
Nov 13, 2007 08:22 PM
coldnorthpole
Mar 3, 2007 07:19 AM
