Sponsored by: Real Truck
F250 steering wander
Old Jul 25, 2004 | 09:19 AM
deatonp's Avatar
deatonp
My 2000 f250 psd has steering wander. Dealer installed new ball joints. Seemed to fix temporarily. Also doesn't seem to want to turn. Front end was aligned with ball joints. Wander is worse when towing. Any help out there?
Old Jul 25, 2004 | 10:33 AM
99f350sd's Avatar
99f350sd
Tie rod ends were bad on mine...
Old Jul 25, 2004 | 08:12 PM
L-N-OR's Avatar
L-N-OR
My '01 seemed to wander especially when towing, after instaling the stiffer add-a-leafs, front and rear, the problem has disappeared. I think the stock new SD F250 suspensions are soft and tend to have a lot of side to side movement.
Just my $.02....
Old Jul 25, 2004 | 09:44 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Have you changed any of your tires lately
Old Jul 26, 2004 | 03:44 AM
deatonp's Avatar
deatonp
changed tires
Yes, I changed tires twice. Had no wander until I changed tires. Had Revo's to start with. They came with 30day ride warranty. They wandered so I change to BFG AT's. They wander also. Then changed ball joints. This fixed temporarily. The truck will start one way. When you try to correct, it just sits there for a second, then goes other way. Is there a way to adjust the steering box?
Old Jul 26, 2004 | 04:31 AM
569104's Avatar
569104
Welcome to FTE!
Yes there is a way to adjust the steering box. On top of the box is an allen head bolt with a lock nut. Loosen the lock nut and tighten the allen bolt in 1/8th turn increments until desired steering response. After making a 1/8th turn adjustment, tighten lock nut and turn steering wheel lock to lock to seat and take for a drive. If after 3 or 4 1/8th turns on allen and play is not gone you probably have other issues. Caution: there is a plastic/nylon ball at the end of the allen bolt and over tightening can damage it. Good luck!
Old Jul 26, 2004 | 05:21 PM
99f350sd's Avatar
99f350sd
Check your front driveshaft ujoints if they are froze you will have major steering issues while in 2 wd.. Jack up the front turn wheels to one side, Lock one hub and turn the wheel by hand it should turn free. Do the same for the other side..
All cause you said temp fixed.... I think this may be your prob...
Old Jul 26, 2004 | 09:13 PM
99f350sd's Avatar
99f350sd
Dah I meant front axle ujoints sorry!!!
Old Jul 27, 2004 | 09:12 AM
jdadamsjr's Avatar
jdadamsjr
https://www.ford-trucks.com/forums/s...hlight=wander+
Old Jul 27, 2004 | 06:17 PM
deatonp's Avatar
deatonp
not yet fixed
Thanks everyone for the info. Going to the dealership tomorrow to see what they say.
skyking897
Apr 20, 2017 11:40 AM
yourofficesupplier
Sep 11, 2016 06:17 PM
02f250fx4
May 2, 2016 11:09 AM
WoodBoss
24
Feb 26, 2016 09:30 AM
Bird-Dog 250
Sep 28, 2015 07:22 AM
