46 Pickup weight
Old Jul 21, 2004 | 07:19 PM
Dodge41's Avatar
Dodge41
46 Pickup weight
I know a while back someone on here was asking about the weight of a 46 ford pickup and after some replies the closest wieght they got was for a 46 with a 6 cylinder and a half a tank of gas weighing in at about 3000 pounds. I was just wondering if anyone has found out anything more about that subject? Is 3000 the closest we got or did someone find any other info and maybe get the exact weight of the pickup?
Old Jul 21, 2004 | 11:14 PM
46yblock's Avatar
46yblock
As I recall, and use as a reference, a 46 1/2 ton with a half tank of gas is 2950 lbs. Mike
Old Jul 22, 2004 | 12:00 AM
Dodge41's Avatar
Dodge41
Is that with the flathead 6 or 8?
Old Jul 22, 2004 | 12:13 AM
46yblock's Avatar
46yblock
8 is what I recall.
Old Jul 22, 2004 | 12:22 AM
Dodge41's Avatar
Dodge41
Ok good. Thanks again for the help mike.
Old Jul 22, 2004 | 12:30 AM
46yblock's Avatar
46yblock
My apologies, to you and me. I looked back through my posts and found the one on 46 weight. 46fordtruck did a weigh-in with a 6 cylinder and the 1/2 tank of gas at 3000 lbs. That means I have more work to do than I thought.
Old Jul 22, 2004 | 12:16 PM
46fordtruck's Avatar
46fordtruck
The 3000 lbs was my weigh in weight when I got my truck registered. In Ca all "commercial" vehicles are required to be weighed to be registered. It was weighed on a CA certified truck scale. 2950-3000, it's all pretty close, but figure around those figures.
Old Jul 22, 2004 | 01:05 PM
Dodge41's Avatar
Dodge41
No need to apologies Mike, that number is close enough and I appreciated the replies. 3000 pounds with the 6 cylinder and 1/2 a tank. Ill just go look up the difference in weight between the 6 and 8 and add it to it. Thanks again for all the help.
Old Aug 14, 2004 | 08:48 PM
bootie's Avatar
bootie
if ya drag ya self to this thread i've poted all the weights for 46-47 trucks courtesy of an old manual i got gross wt. of 1942 3/4 T PU
https://www.ford-trucks.com/forums/s...89#post1856389
you guys need any more info just ask
jp45601
2004 - 2008 F150
Mar 30, 2013 01:13 PM
fast68
Mar 4, 2010 11:27 PM
Pest007
Aug 12, 2008 02:33 PM
BIGFISH70
2004 - 2008 F150
21
Mar 19, 2007 09:21 PM
46yblock
1947 and Older Ford Trucks
Feb 20, 2004 11:14 AM
