1978 - 1996 Big Bronco
Map sensor / engine won't run
Old Jul 19, 2004 | 10:25 PM
rickye's Avatar
rickye
Cool Map sensor / engine won't run
i have a 89 bronco with 302 only starts w/ map sensor unpluged .i am not getting any codes runes fine in park as soon as you put it in gear it kills and wont start for about an hour if you plug the map in wile running it kills replaced map sensor,cap,rotor,pluges,module,tps,wires,fule pumps,timing chane,gears,fule relay,computer and still doing the same thing brought it to 3 different techs they have no idear please help thanks
Old Jul 20, 2004 | 10:10 AM
Kemicalburns's Avatar
Kemicalburns
is the ecu new? if not that could be your whole problem. now tell me why you replaced all of those things, what were your problems in the beginning? there is also a fuel cutoff switch located under the passenger side dash area. this could be malfunctioning .
Old Jul 20, 2004 | 01:42 PM
mustangman65_79's Avatar
mustangman65_79
It shouldn't start with MAP sensor unplugged, as far as I know. Maybe somethings wrong with the wiring going to the map sensor.
Old Jul 20, 2004 | 08:02 PM
rickye's Avatar
rickye
the ecu is not new.all of the things i replaced needed to be replaced except the tps and computer. i am getting 43 lbs of fule pressure now was getting 10 lbs still no go. i talked to a tech at a ford dealer he seem to think it is the ats (air temp sensor) he is coming to check it tomorrow i will let you know .
Old Jul 21, 2004 | 06:55 PM
rickye's Avatar
rickye
the tech from ford did not show !
Old Jul 27, 2004 | 10:24 AM
mustangman65_79
so what is going to happen?
nwjones18
May 7, 2015 07:44 AM
AKsnow93
Apr 15, 2011 01:59 AM
shovelheadx2
Nov 12, 2009 06:45 PM
FordPerf300
25
Dec 29, 2007 03:46 PM
master link
Aug 16, 2006 09:46 PM
