Sponsored by: Real Truck
Air Filters?
Old Jul 23, 2004 | 07:33 AM
  #46
jdadamsjr's Avatar
jdadamsjr
Yep, Greg, John, and Bob isn't that great that we each have different results
Maybe that's why they sell so many different COLORS of trucks - so we can get the one we want and not have to convince everyone that THAT'S the best color
Old Jul 23, 2004 | 10:35 AM
  #47
PeteC's Avatar
PeteC
I just checked my intake tube. No dust. K&N installed for about 35,000 miles. I noticed it can be a little tricky to get the filter seated properly. Also, my K&N had one of the foam gaskets coming loose. It could easily get folded over and create an air leak.
Old Jul 23, 2004 | 12:39 PM
  #48
HDMustF250's Avatar
HDMustF250
To date I have to oil samples with two different filters installed.
When I bought the truck it had a Hastings Air Filter - oil sample silicon level 6
I replaced that filter with a dual filtration oil high flow - oil sample silicon level 8
Since I have seen factory filters with as much as silicon level 50 from oil samples, I am going to accept the 8 for now.
Old Jul 23, 2004 | 04:43 PM
  #49
mcjones44us's Avatar
mcjones44us
Does the Tymar come with the new battery tray?
You guys have me convinced to buy the Tymar but am curious whether the battery tray comes with the kit?
Old Jul 24, 2004 | 09:59 AM
  #50
johnsdiesel's Avatar
johnsdiesel
I believe it does. Why don't you call and ask Dale (owner)? 509-922-8785
Old Jul 25, 2004 | 11:06 AM
  #51
OMCUSNR's Avatar
OMCUSNR
Originally Posted by PeteC
JackFlack: Sorry, didn't mean to repeat your link.
Chocktaw Bob: You are right in that the best bet is to test your own vehicle. And yes, we have to be careful in trying to separate fact from fiction on the web.
All: There is a HUGE discussion on the Chevy diesel forum regarding some air filter tests that were recently done. The K&N did not look very good, but it is hard for me to believe it was as bad as they indicated. A guy from K&N is interacting with the guy that initiated the testing, which was supposedly done by an independent lab. I will be following this discussion for sure.
http://dieselplace.com/forum/forum_p...642&PN=1&TPN=1
Did you guys look at the data this link provided?? This is from the manufacturer of test stands that the industry uses to test their filters for bragging right (excuse me, marketing data). The idea presented that the only test that matter is your own I have a problem with. I don't have the financial resources to run a completely un-biased test, and just slapping a filter on my truck & looking at it doesn't cut it as unbiased or scientific.
One oter thing that is swaying me is the techs over at flatratetech. These guys have no lost love for Ford Corp., and are there to help people like you & me. Not many of them will recomend an after market of any brand.
Old Jul 27, 2004 | 12:14 AM
  #52
Choctaw Bob's Avatar
Choctaw Bob
Another thing about my K&N, it will be the last filter I ever buy for this truck. It just takes a few minutes to clean and recharge the filter. Never have to buy another.
Old Jul 27, 2004 | 12:32 AM
  #53
daimon1054's Avatar
daimon1054
K&N filters work! Nothing that I have ever seen gets dirt into an engine better! How these thing still sell is beyond me, sure thay make more power but so does running no filter and heck both ways filter just as well!
Old Jul 27, 2004 | 12:51 AM
  #54
Choctaw Bob
If you would take a look at my Blackstone report in my gallery you would see that my K&N FIPK in a very dusty enviroment, filtered the air so well that the silicone content tested at half the level a normal air cleaner is expefcted to text.
This is in addition to the dyno numbers of 387 HP and 723 Ft Lbs of torque.
You would have to admit that My k&N FIPK works very well on my truck!
Don't you think?
Old Jul 27, 2004 | 02:07 AM
  #55
Jackflack's Avatar
Jackflack
From what I saw and read of your (Choctaw Bob) Blackstone report, it didn't look good at all.
Old Jul 27, 2004 | 08:02 AM
  #56
psdtenn's Avatar
psdtenn
It doesn't look good to me either. Low viscosity & flashpoint numbers coupled with high fuel percentages = oil dilution. Iron levels indicate excessive wear. Silicon levels could be lower by using a better air filter. Here's the numbers on my last oil change (5691 miles on oil, 188,191 miles total):
Aluminum 4
Chromium 1
Iron 15
Copper 3
Lead 1
Molybdenum 1
Tin, Nickel, Manganese, Silver, Titanium, Potassium, Boron, Barium 0
Silicon 4
Sodium 1
Calcium 3595
Magnesium 7
Phosphorus 1065
Zinc 1209
SUS Viscosity@210°F: 73
Flashpoint °F: 420
Fuel Percent: <0.5%
Insolubles: 0.3%
Antifreeze: 0%
Water: 0%
Old Jul 27, 2004 | 09:34 AM
  #57
jdadamsjr's Avatar
jdadamsjr
I don't understand how that logic works...
Since I've got a stock filter, a beter filter will get my Silicon better than the 9 range ? (it's posted in my gallery)... so it's not necessarily the filter....
Old Jul 27, 2004 | 09:43 AM
  #58
psdtenn's Avatar
psdtenn
A different air filter can make silicon levels drop as they did in my case.
Old Jul 27, 2004 | 10:55 AM
  #59
HDMustF250's Avatar
HDMustF250
I just received my second oil analysis back.
The first one was done with a Hastings paper filter Silcon=6
The second was done with a foam oil filled filter Silcon = 8
Hence I am tossing the oil filled filter for the paper ones again. Hopefully to reach the 4 range. I want as little as possible hoping to get as many miles as possible out of my truck.
JR
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
