For the 1st 15K used Motorcraft. Oil samples showed slight amount of dirt. Well below danger levels. Switched to K&N. Oil samples came back much better and stayed that way. Sample every 7,000 miles. Have run over 100K and still strong. Just broke in. Punched a 3" hole in plastic grille right in front of fresh air intake to allow cooler air in. Seems logical that it would draw cooler air instead of air drawn around raditor assy. Talked to Ford, they said the reason they opted not to do that from factory was a chance of plugging with snow in certain conditions or applications. Don't plan on that being a problem. They seemed to like the idea. Only thing is that you do catch more small critters. Anyway seems to work for me.
Don't use a K&N with the 6.o liter diesel! Too many dust type particles get through and interfear with the variable vanes in the turbo. Factory type filter only..
Well Lasharoo, Turns out that K&N doesn't even make an air filter for that application. Where did you get your inside information on the lack of effeciency on a filter that as of this date does not exist?
Does anybody have any proof (independent tests, worn out engines...) that the K&Ns let more dirt in?
Yes, and it's based on their own statistics. K&N claims a filtration rate of between 97-99%. Their filters tend to filter right around 97% when clean and get more efficient when dirty. Other testing done by other companies seems to be right in line with 97% for a clean filter. I don't think K&N lies about their own filtration rate on their website. On the other hand, the Donaldson filters in the 6.0, AIS, and Tymar filter at 99.8% when clean and 99.9% with some dirt on the filter media. Again, these are not my numbers for the K&N filter, they are posted on the K&N website.
I'm not disputing your numbers. My problem is for someone to tell someone else in language that a person would have you believe that their firsthand knowledge is that K&N should not be used on a 6.0 because it will cause damage to the turbo, when in fact there is no application so how can that be proven or disproven.
It has been my personal experience that a K&N is more efficient in keeping dirt out of my 7.3 and my other engines based on oil sample reports as compared to OEM.
Once again, they are NOT my numbers, they are K&N's numbers, which show their filter to be far less efficient. I have know several people who have had damaged turbos due to K&N filters. Use the search function on this website and you'll come across some of these people, and yes, they did know how to install and maintain a K&N filter.
No offense, but I think it's crazy that you won't even believe the numbers from K&N themselves.
For those that say the 6-oh K&N air filters don't exist....
Choctaw Bob has had one on his 6-oh for at least 6 months... and his blackstone reports show less silicone than averages and not much more than my stock filtered 6-oh does on a lot less miles
so I'm just not sure WHAT to believe !
Have had K&N's for years and never had a dusted engine personally,
no matter what I do though, I'm just getting my monies worth out of this stock filter first...
Wrong!
I finally have the ammo to put this false rumor to rest once and for all!
Check my Gallery!
I have a K&N FIPK on my 6.0 PSD. It made 387 HP and 728 Ft Lb of Torque with a Predator and no other mods.
My Blackstone oil sample showed a silicone content of nearly half normal levels.
The K&N provides superior filtration and more power at the same time!
The factory filter also does a much better job filtering than any of the reusable filters. The Donaldson specs are 99.8% for a clean filter, 99.9% when it has some dirt on it. K&N's numbers, as posted on their own website, range from 97-99%. That doesn't seem like much, but it is. Take a clean Donaldson paper filter against a clean K&N filter. The K&N is letting in 15 times more dirt/dust. Again, not my numbers, but the numbers posted by K&N and Donaldson.
The test data simply doesn't support this. K&N Posted independent lab data showing their filters filter within .001% of the stock test filters.
My oil test data proves that my K&N KIPK filters better than the stock filter.
Bob, I'm not disputing anyone's choice to use a K&N filter, but my data is based on K&N's own figures and the figures from Donaldson for their filters. All the independant tests I've seen support the numbers that K&N posts on their website. I don't think they underestimate their own product with their numbers, but their numbers are well below those of paper filters.
Well, I'll put my flame retardent undies on first, here...
I just got through a VERY interesting read over at the diesel place for Damx's. They were able to cajole an independant testing lab (actually the firm that makes filter test stands) to run tests on Ummmmm 7 or 8 different stock & aftermarket filters (unfortunatly, Donaldson didn't make the list). It was a bit long & generated much discussion.
Seems the factory (AC/Delco) paper filter held up the best.
These were tests run just like the manufactur's run & they posted the results out there for all the world to see.
From those results, and what the guys over @ flatrate say, I'll stick with the OEM Donaldson. I can get about 6 for the price of the PRO-guard 7.
This thread is turning out like almost every other air intake thread. I guess that's why I usually recommend using the search function now when this topic comes up.
Bob, if you really want a lot more air and filtration you should consider retrofitting a Tymar intake for your truck.
