E4OD question, operating
Old Jul 19, 2004 | 09:26 AM
SSmike1's Avatar
SSmike1
i have an operating question,
If, while towing a trailer, should you turn the OD Off?
I have found that she works alot better when the OD = OFF
while towing a trailer.
what do you do?
what do you recommend?
thANks
Old Jul 19, 2004 | 09:53 AM
KwikFord's Avatar
KwikFord
Never tow anything when in overdrive.
Turning the overdrive off eliminate torque converter lock up and 4th gear.
Old Jul 19, 2004 | 10:18 AM
jim henderson's Avatar
jim henderson
Depends what you are pulling. The key is, "if it hunts gears, turn off OD"
I have a 94 F250 E4OD and tow an 8,000# trailer a fair amount. Usually I leave it in OD, but if I am coming up to a good long hill I downshift before I get there and build up some speed. My truck likes to run at about 60mph on hills, if it drops below about 50 then I get into the 2-3rd gear back and forth routine if it is s tough hill.
I also drop into 3rd if the tranny hunts, like on slight long slopes of a heavy head wind.
Of course I had my 94 tranny rebuilt to take advantage of the improvements and to be "bullet proof" for towing.
The manual and Trailer Life magazine say pretty much the same thing "if it hunts, downshift".
Good Luck,
Jim Henderson
Old Jul 19, 2004 | 01:25 PM
Casey's Avatar
Casey
That's not what Ford recommends.
No it doesn't. Turning off the overdrive eliminates fourth gear, but does not eliminate torque converrter lock. The torque converter will lock in third gear with the overdrive on or off.
Old Jul 19, 2004 | 04:08 PM
KwikFord's Avatar
KwikFord
I stand corrected........ my errors.
Old Jul 19, 2004 | 06:20 PM
SSmike1's Avatar
SSmike1
well,
casey is correct on my 1991 E350 E4OD,
the Tranny TC still Locks UP, when OD = OFF,
in other words, the TC locks up in 3rd gear! or 4th gear on my truck, van.
Old Jul 19, 2004 | 06:26 PM
SSmike1's Avatar
SSmike1
and yes,
as soon as i start hitting an uphill grade while towing,
the trannt starts hunting between 3rd & 4th,
so...
I turn 4th = Off, which is OD=OFF.
anytime i am towing.
Old Jul 19, 2004 | 07:34 PM
mike93's Avatar
mike93
casey is correct, the t/c does lock up when in O/D = OFF or O/D= ON. you'll even get T/C lockup when in second if speed is above 30mp. but it all depends on how you are accelerating. the only time there is no lock up is when starting out, manual low & manual 2. and also right about O/D= OFF if the tranny is hunting back and forth. also O/D=OFF! when decending down the other side. coast clutch is over ridden and you'll get 3rd gear braking.
Old Jul 19, 2004 | 09:32 PM
SSmike1's Avatar
SSmike1
OK
im so glad you mentioned the Coast Clutch,
what the heck is a Coast Clutch?
what does it do,
and why?
thanks
super bike mike
Old Jul 20, 2004 | 06:32 AM
Casey's Avatar
Casey
The coast clutch comes on when the shifter is in 1 or 2, or when the transmission is in third gear with the overdrive turned off. It provides engine braking. There is engine braking in fourth gear all the time, but since fourth is overdrive there is not much engine braking because the engine isn't turning very fast.
Old Jul 20, 2004 | 06:42 PM
BOJOFASO's Avatar
BOJOFASO
ford recomends towing in a normal gear position. the overdrive switch does NOT disable the lockup converter but it does keep the 4 th or overdrive gear from working. i tow od off because at low speeds the torque converter will overheat and swell. this in turn will make your front seal leak. enough of overheating and you will be replacing the tc and the front seal.
XolieX
2004 - 2008 F150
17
Mar 24, 2008 09:44 AM
ol'yeller
All Things Towing
Oct 18, 2006 10:16 AM
jamesgs47
Mar 20, 2004 01:23 AM
bigolbob
Dec 11, 2003 01:31 PM
TallPaul
All Things Towing
Apr 13, 2000 09:30 AM
