E4OD Question
Old Jul 19, 2004 | 08:26 AM
Jrock909's Avatar
Jrock909
E4OD Question
So is the e4od transmission a 3 speed with overdrive, or 4 speed automatic with overdrive???
Jason
Old Jul 19, 2004 | 09:24 AM
SSmike1's Avatar
SSmike1
the E4OD
is a 4 speed auto,
Almost every transmission, that says overdrive,
just means it has 4 speeds, vs a 3 speed.
WHY, cause it sounds good that you have Over Drive!
the first 3 gears are Multiplication of torque,
and the 4th gear is a 1:1 ratio, or less, like .9:1 ratio,
which is What Over Drives do.
all in all
they are ALL 4 speed automatic transmissions now a days.
Old Jul 19, 2004 | 01:26 PM
Casey's Avatar
Casey
The E4OD has four ratios, and one of them is an overdrive ratio.
Old Jul 19, 2004 | 07:38 PM
mike93's Avatar
mike93
a ratio of 0.73:1 to be exact or not.
Old Jul 19, 2004 | 09:30 PM
SSmike1's Avatar
SSmike1
ill get the owners manual out tomorrow
and look.
:0
Old Jul 20, 2004 | 06:33 AM
Casey's Avatar
Casey
The correct ratio is 0.71:1, but what's 0.02 among friends?
Old Jul 20, 2004 | 06:48 AM
TallPaul's Avatar
TallPaul
To be qualified as an "overdrive" tranny, the top gear must be less than a 1:1 ratio. While the E40D is a 4 speed automatic, it effectively is a 5 speed. Most automatics are effectively one more speed than rated because of the torque multiplication effect of the torque converter, which upon take off doubles up the torque at the expense of halving the speed, so you get an extra low take off gear. That is one reason the first gear in an automatic is usually not that low, typically 2.50:1, but the torque multiplication effect will usually double that for digging out of the hole. I think the E4OD on my motorhome actually has more than a doubling effect, but can't remember the exact amount (2.4 maybe).
Old Jul 20, 2004 | 06:36 PM
BOJOFASO's Avatar
BOJOFASO
the e4od is a 4 speed with 4th being overdrive it also has a lock up converter that will lock up in any and all gears
. so i guess you would call it a 4 speed trans.
sorry to disagree with tall paul but it only has four different gears not 5 but it does feel like 5 when the converter locks up.
Old Jul 20, 2004 | 07:35 PM
TallPaul's Avatar
TallPaul
Well, guess I could have said it differently. The E4OD is a 4 speed, but the bonus is that first gear functions like a lower gear on take off and so you sort of get a variable ratio out of first.
Old Jul 20, 2004 | 07:38 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Whatever the gears are called, their ratios are:
First = 2.74, (this could be off, I've also heard it's 2.84)
Second = 1.55,
Third = 1.00,
Fourth (OD) = 0.71.
For comparison, my C6 auto's ratios are:
2.47, 1.43, 1.00
RCrawler
May 4, 2020 02:12 AM
Jrock909
Aug 11, 2006 04:54 PM
Jason8705
Sep 10, 2004 12:11 PM
jason79045
Sep 7, 2002 10:05 PM
