83 302 compression specs??
Old Jul 19, 2004 | 12:19 AM
luvinfords's Avatar
luvinfords
Imma trying to find the compression specs for my 83 302 block, I did know them but forgot, anyways if anyone has a link , answer, or the specs, that would help out for a routine maintance on my motor.
BTW I did a search and found everything but the compression specs in here and that google thing, lol
Thanks Steve
Old Jul 19, 2004 | 01:08 AM
fordeverpower's Avatar
fordeverpower
about 8.5 without looking!
Old Jul 19, 2004 | 01:10 AM
fordeverpower
1980-1985 2v is 8.3 to 1. That was quick! Good luck
Old Jul 19, 2004 | 01:53 AM
luvinfords's Avatar
luvinfords
KEWL, Thanks,, where did ya find that at ...need more specs PLZ
Old Jul 19, 2004 | 01:55 AM
fordeverpower
a book that i have! Hey let me know what you want to know and i will help you!
Old Jul 19, 2004 | 03:20 AM
luvinfords's Avatar
luvinfords
mmmm,,,, how much is the p.s.i. for each cylinder - for a compression test
Old Jul 19, 2004 | 05:21 PM
fordeverpower
There specs are 100 psi is the lowest reading and some considered it dead! You want your psi to be with 80% of each other. For instance of high of 150psi should have a low of 120psi. An old engine might have between 120 to 140 psi. comp ratio and compression are not realted.
SKaero
Aerostar
Aug 16, 2016 11:59 AM
notch83
6.4L Power Stroke Diesel
Nov 9, 2012 01:02 AM
spidermonkey
May 14, 2008 10:50 PM
Nightrain
Aug 19, 2007 11:37 AM
Katmandu2
Aug 30, 2003 02:27 PM
