351W HO Specs
Old Aug 19, 2007 | 09:39 AM
Nightrain's Avatar
Nightrain
351W HO Specs
I was thinking of swapping in a 83-87 351 Windsor HO in my 302-powered F150.
I was wondering what the factory horsepower and torque numbers are?
Nightrain
Old Aug 19, 2007 | 10:48 AM
Conanski's Avatar
Conanski
About the same as the 94+ roller cam EFI 5.8... 210HP, 330lb/ft TQ, but the TQ peak was at a higher rpm due to the carb intake. The only real difference between that motor and every other 351 up to '94 is the cam. Speaking of carbs.. are you gonna make it EFI when you put it in? If so you may need to change the cam unless you use a mass air system.
Old Aug 19, 2007 | 11:37 AM
Nightrain's Avatar
Nightrain
Thanks, Conanski.
I plan on carb'ing the motor when it goes in, if I do go this route.
Better numbers on the HO than what I thought!
Nightrain
IsaacJR75
Jan 30, 2023 04:28 PM
ScottInTexas
Jun 12, 2007 12:26 PM
Nightrain
Jan 23, 2007 02:03 PM
Nightrain
Aug 5, 2005 11:41 AM
Nightrain
1983 - 2012 Ranger & B-Series
Jul 26, 2004 07:31 AM
