Bronco II Ford Bronco II
rebuilt enigne
Old Jul 18, 2004 | 09:07 PM
chadscanadian's Avatar
chadscanadian
rebuilt enigne
Hi i am gonna get a new engine for my 84 bronco2 soon i was wondering what actually comes on a rebuilt engine do you get a water pump or anything like that.,
Old Jul 18, 2004 | 09:17 PM
Help I M Stuck's Avatar
Help I M Stuck
Don't know where you are from..but if you are looking for a 2.8L I have one I just pulled from my 85 BII and it only has a little less then 3000 miles on it. It has the water pump, oil pan, valve covers, intake, carb still on it. basically all you have to do is probably change carbs since mine I think has a bent piece on it. The headders are on there also and can be used but the cross over pipe for the smog pump has rusted. I did block the one port on the header sinch it broke on in a place that i couldnt get out. It's just a matter of cutting the other end of the cross over pipe off and plugging it. All that stuff does is connect to the smog pump. It passed inspection like this for me. The other thing if u use the headers is you will have to drill out the flange bolt holes and use new bolts since they wouldnt come out and i cut them. I'm looking at $500 for it the way it is. I can take pics tomorrow and send them. You can reach me at 443-865-9885..Jeff... I even have the original warranty papers from Recon that came with the motor when i purchased it.
Old Jul 18, 2004 | 09:50 PM
chadscanadian
well iam up in canada so the shipping wouldnt be worht it
Old Jul 18, 2004 | 09:54 PM
Help I M Stuck
true
Old Jul 19, 2004 | 12:11 AM
ShawnZ's Avatar
ShawnZ
how much difference in power does the rebuilt engine have, compared to one with say... 140000 miles on it?
I have no idea, maybe you would, how much shioping on somethiNg like this would be to Arizona
Old Jul 28, 2004 | 12:46 AM
'87BroncoII's Avatar
'87BroncoII
if you buy a new long block itll come with everything you need and any motor you buy should have a parts list some will even have a list of parts the you have to salvage from your old engine usually thell come with almost every thing except the intake, distrubtor, fly wheel etc...
collinft
Nov 7, 2015 08:27 PM
berry1234
Large Truck
Sep 24, 2013 10:13 AM
dino360
13
Nov 29, 2005 02:38 PM
92EBBronco
Michigan Chapter
Sep 23, 2002 10:01 AM
babybroncoii
Bronco II
May 2, 2001 08:28 PM
