Prime To Start
Old Jul 17, 2004 | 08:07 PM
meangenejr's Avatar
meangenejr
Prime To Start
I have a 1981 f100 ranger w/6 cyl and 1 bbl carb. If It is not started within about two hours time, you have to pour a little gas into the carb to get it to start!!!!!! After starting it runs great and turns on and off with no problems. I have ckecked the inlet filter, line from pump, air cleaner and every thing else under the sun that would impede the flow with no luck! Anyone have any ideas??
Old Jul 17, 2004 | 08:15 PM
southernfordman's Avatar
southernfordman
i would say bad fuel pump or maybe carb
Old Jul 17, 2004 | 08:58 PM
Dave257's Avatar
Dave257
vapor lock ? check the gas line is not touching anything that gets hot.
Dave
Old Jul 17, 2004 | 09:08 PM
nightshifter's Avatar
nightshifter
sounds to me like the fuel in carb bowl might be draining out. it's been a few years, but that seems like that might cause it. Have you ever rebuilt the carb? Carb kits are cheap, I'd try finding a carb at a junkyard, get a kit, rebuild it an swap it. If that seems too much, maybe you can try some gumout carb cleaner, it may just be a tiny bit of debris causing the problem.
Old Jul 17, 2004 | 09:32 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
I saw one like this where the carb gasket was dried out and when the choke came on, it just sucked air around the base of the carb instead of drawing fuel into the carb. Just a thought!
Old Jul 18, 2004 | 04:23 AM
nightshifter
if it's the gasket, maybe try spraying some starting fluid around the base of the carb while having a helper crank the motor. I'd disconnect the fuel line to keep it from priming things and you having to wait a couple more hours to check things again.
Old Jul 18, 2004 | 12:05 PM
meangenejr's Avatar
meangenejr
Smile Priming problem solved (I think)
I think maybe i've located the culprit responsible for having to constantly prime my carb! The hose w/associated emissions cannisters coming from the smog pump to a bung beneath the carb was broken off at the bung. The carb was sucking air instead of gas. I have no idea what the little cannister connected to the bung that broke is called. The fitting screws into the intake under the carb is like a pipe fitting. I can't get the fitting out so i have cemented a coin over the hole into the intake. Later today or tommorow, I'll try starting it and see what happens.
Thanks to all you guys who offered your opinions and help. I'm hoping this takes care of the problem!!!
Gene
K9sicem
Dec 27, 2013 07:33 PM
Bayou_bike87
Oct 11, 2013 12:09 PM
logan.hawes
Sep 19, 2011 01:03 PM
abklages
13
Jul 30, 2011 10:11 AM
Ford460BBpower
Aug 27, 2002 08:06 AM
