460 eats distributor gears
Old Jul 17, 2004 | 12:37 PM
tuxedo's Avatar
tuxedo
Unhappy 460 eats distributor gears
I have a rebuilt '73 Lincolin 460 installed in my '79 Bronco. Modifications include a Ford Truck rear sump pan with the proper pickup tube and dip stick and a Melling M-84D Oil pump. all seemed well. However, in less than 200 Miles the distributor/oil pump drive gear failed. Whats up.
Tux
Old Jul 17, 2004 | 03:28 PM
ozzy460's Avatar
ozzy460
i had similar problem and it turned out to be the bushing at the base of the distibitor was wore causing it to wander. chewed up on gear and 3 or 4 cap and rotors before i figured it out
Old Jul 17, 2004 | 08:26 PM
tuxedo's Avatar
tuxedo
Thanks, However, my problem occured with a distributor with new bushings.
Tux
Old Jul 17, 2004 | 10:37 PM
whall's Avatar
whall
I have the same set up only using a 76 lincoln block, and have had no problems. I had a similar problem with a 351W in a 77 F-100 turned out that the oil pump bolts had backed out a little and let the shaft wonder which ate up 3 distributor gears and on the final one I chewed the cam gear up too. When I took dropped the pan I found the loose bolts. Don't know if that will help but I hope it does
Old Jul 18, 2004 | 09:50 AM
tuxedo's Avatar
tuxedo
Thanks for Your input. I recently replaced the Oil Pump Drive Shaft with A heavier one From ARP. At that time my pump attachment bolts were tight. I do believe that You have pointed me in the right direction.
Old Jul 19, 2004 | 09:15 AM
77460f150's Avatar
77460f150
What type of dist gear (s) are you installing?? If you have an aftermarket camshaft installed you may need to be useing a "hardened" (bronze) dist. gear, available at any high performance shop or mail order catalog from summit or jegs (MSD part#MSD8581, price $40). The camshaft is made of harder steel than the stock gear and will destroy a stock dist gear quickly.
490SCJ
Missouri Chapter
Feb 4, 2005 11:27 AM
BILL460FOX
Dec 29, 2004 03:20 AM
nevereverquit
Dec 29, 2003 06:59 PM
n3ffn
Sep 28, 2002 01:12 PM
andym
Sep 3, 2002 11:48 PM
