460 oil pump
Old May 7, 2000 | 06:37 PM
n3ffn's Avatar
n3ffn
460 oil pump
I have a 1966 ford f-100 with a early 460.The other day the oil pump seized causing the distributor gear to break-is this a common problem?
Also I need a oil pump-should I go stock or high volume? I had a very knowledgable mechanic tell me for the street use a stock as the high volume will cause bearing erosion. Help!
Old Sep 19, 2002 | 11:15 AM
qtrmiler's Avatar
qtrmiler
460 oil pump
Old Sep 28, 2002 | 01:12 PM
LxMan1's Avatar
LxMan1
460 oil pump
Nit common on the oil pump lock-up, but it can happen. I had it happen to me in a 71 351C before. A high volume pump is fine. Turcks have a 6 qt. capacity and usually don't turn much over 5000rpm, so there is little chance of sucking the pan dry.
Team Danger
Sep 1, 2009 07:57 AM
smolicht
May 9, 2008 08:14 AM
ford390gashog
21
May 13, 2005 09:47 PM
TallPaul
Oil & Lubrication
Oct 26, 2002 09:24 PM
85bronco
1978 - 1996 Big Bronco
Oct 6, 2001 08:26 PM
