please Help
Old Jul 11, 2004 | 01:57 AM
OneSweet81's Avatar
OneSweet81
Question please Help
i bought a aftermarket volt meter and at first it worked fine but after a month or so it started missing up, it like dances, and at an idle my lights get dim and it reads less than 6 volts , and turns my radio off and it is really driving me crazy i just replaced the altinator and it is still doing it please Help! thanks Trevor
Old Jul 11, 2004 | 02:01 AM
Spktyr's Avatar
Spktyr
How did you wire it in?
Old Jul 11, 2004 | 02:08 AM
OneSweet81's Avatar
OneSweet81
grounded it to the frame and ran the positve to the fuse Box!
Old Jul 11, 2004 | 02:37 AM
Spktyr's Avatar
Spktyr
OK, and if you disconnect it, do your problems go away? If not, then you have some other problem - probably a bad cable from your alternator to the starter relay or battery, depending on how your truck is set up.
Old Jul 11, 2004 | 07:47 PM
pmammen's Avatar
pmammen
your voltmeter is actually working right. it will show the fluctuations you are experiencing. look for loose connections at the starter relay. if there was an ammeter factory installed there could be loose wires there.
Old Jul 11, 2004 | 07:53 PM
locknkey's Avatar
locknkey
Ampmeters are not supposed to go to ground, you are measureing DIRECT CURRENT, meaning if its chargeing the needle will move to the C if its connected right, DO not connect the other side to ground, you are just frying your alt and voltage regulator....
Old Jul 11, 2004 | 08:23 PM
OneSweet81's Avatar
OneSweet81
thanks for the info yeah my stock ampmeter is still hooked up i will try that thanks and my instructions on the aftermarket voltmeter it says to ground it to the frame and i kinda fixed it i just grounded it to the frame better but it is still doing it a little bit!
Trevor.801
Dec 13, 2014 12:57 PM
Trevor.801
Mar 12, 2014 03:44 PM
Filthy1955F100
Ford Truck Parts for Sale
Feb 22, 2014 10:42 PM
Trevor.801
Jul 11, 2013 11:10 AM
Trevor.801
Dec 28, 2012 08:57 AM
