Aerostar Ford Aerostar
Transmission is reversed
Old Jul 10, 2004 | 12:02 AM
Bomber1973's Avatar
Bomber1973
Exclamation Transmission is reversed
lol I know sounds wierd but the transmission in the 93 aerostar I just got the park is reverse and the reverse is park D1 and D2 still puts it in drive anyone know what would cause this to happen? I've never heard of transmissions doing this
Old Jul 10, 2004 | 01:23 AM
428_cobra_man's Avatar
428_cobra_man
I have Had a similar Problem.. I would first check the shift linkage.(maybe out of adjustment) If thats not the problem it could be the detent arm i would pull the pan off the tranny and have a look at that other than that i can't think of anything else.
Old Jul 10, 2004 | 08:50 AM
Bomber1973's Avatar
Bomber1973
tky
tky for the info muchly appreciated all the help any one on could help on the wiring thats in the area where the raido is i've got no interior lights and when i touch the bare wire i get the lights working and the door chime. its a fixer van i picked up tky again
Old Jul 10, 2004 | 04:09 PM
JTHill24's Avatar
JTHill24
A missing Ground? Sounds like your making a ground when you touch the wire.
Old Jul 10, 2004 | 05:20 PM
Bomber1973's Avatar
Bomber1973
will that also cause a sparks? tky
Old Jul 14, 2004 | 02:51 PM
JTHill24's Avatar
JTHill24
Bomber1973:
On your Transmission.
Is the shift lever on your transmission pointing up or down? (On mine it's down)
That would make a differance into which gear it would go.
Somebody might of put in a transmission that works backward.
JLmissouri
16
Jan 11, 2012 02:42 AM
mikerans
Aug 8, 2011 09:59 PM
dangerranger10
1983 - 2012 Ranger & B-Series
Oct 29, 2010 01:23 AM
mackdog
Aug 7, 2008 07:49 PM
