Best front leveling Kit
Old Jul 9, 2004 | 08:09 PM
Powergod's Avatar
Powergod
Question Best front leveling Kit
I have recenly purchased a 2000 Excursion with a PSD. I want to level the front end. What is the best way to do that. I already have 33'' tires on the way.
Old Jul 10, 2004 | 08:49 AM
spartan's Avatar
spartan
Easiest - least expensive - the 2.5" Edge mini spring pack. Next the 3" Fabtech hanger kit. Better ???? option - Edge 3" or 4.5" kit. The 4.5" is my reccomendation but it may take you places you don't want to go, such as: new track bar relocation bracket, drop pitman arm, rear block lift, all new shocks, etc. My truck is exactly level lifted 4.5" front and 2" in the rear. Good luck.
Old Jul 10, 2004 | 09:04 AM
Powergod's Avatar
Powergod
I would like to do it cheap. I am only going to run 33" tires so I don't need too much lift. Leveling should be enough.
Old Jul 10, 2004 | 12:29 PM
daimon1054's Avatar
daimon1054
What does rearching your springs cost?
Old Jul 12, 2004 | 03:13 PM
spartan's Avatar
spartan
More than the mini spring pack. C code spring are reverse arched and almost impossible to do anything with from a rearching perspective. Mini spring pack and two hours of your time + air tools, two jacks, etc.. Do the passenger side first, then drivers side. If you don't want to do it - pay $100 - 150 for install of mini packs and new front shocks. You will need longer front shocks.
Old Jul 13, 2004 | 06:02 AM
DBush's Avatar
DBush
How much does the mini spring pack effect the ride?
Old Jul 13, 2004 | 11:17 AM
spartan's Avatar
spartan
None as far as I know. Doesn't change anything other than ride height and a decent pair of front shocks is definately going to help the ride.
Old Jul 13, 2004 | 11:35 AM
neilc88's Avatar
neilc88
Thanks to Spartan's previous advise, I went with the Edge mini spring pack. No change to ride, but a better look. The tire/wheel wells needed a little more clearance due to the 285 tires. This is a 2" kit and will level the truck. Althought level, the X appears to look nose high. The next day I put 4" F-250 blocks in the rear. No vibration problems. This kept the factory rake. I kept the factory front and rear shocks until I come up with some more $.
The mini spring pack is MUCH easier than new springs to install.
MJ76
Feb 13, 2014 10:55 AM
crapr6
Dec 31, 2011 07:50 PM
armydude
Sep 27, 2011 06:21 PM
Borrego97
May 14, 2010 02:49 PM
jmarblack
Jul 15, 2007 09:01 PM
