Need Help with my SUICIDE Clutch!
Old 07-08-2004, 10:11 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
The clutch on my 84 F250 engages about an 1" or 2 above the floor. It has a slave cylinder down on the fork. I see no adjustment on it at all.
Short of replacing the cylinder, what can I do ???
Old 07-08-2004, 10:19 PM
hoxiii's Avatar
hoxiii
hoxiii is offline
Let out on the clutch slowly.
Make sure you're master cylinder is full of fluid and that the pushrod that actuates the clutch fork is in its little dimple. That's where to start.
Justin
MontanaFord's Avatar
MontanaFord
MontanaFord is offline
add DOT-3 brake fluid to the little plastic master cylinder on the firewall just to the inside of the brake booster/master cylinder...your hydraulic clutch runs off of DOT-3...i know...sounds funky, but that's what the chilton's calls for...
MontanaFord
Old 07-09-2004, 12:11 AM
Katmandu's Avatar
Katmandu
Katmandu is offline
Justin
Yup. Done that already.
Is there any way that I can shorten/length the push rods (on the back of the clutch master cylinder or the slave cylinder) to make it engage higher ??
Which direction do I need to go ???
Or what do I need to replace ??
Old 07-09-2004, 12:21 AM
hoxiii's Avatar
hoxiii
hoxiii is offline
Try this: where the shift fork goes into teh bellhousing there ::should:: be a rubber boot. remove this boot (if it's there) and look inside. see if the throwout bearing is still on the fork. Right now i'm trying everything that could do it but that won't cost anything (or much) to fix.
Justin
Old 07-09-2004, 12:22 AM
bigbrown84truck's Avatar
bigbrown84truck
bigbrown84truck is offline
when u checked the dot 3 fluid for the clutch you did take the inner cap out correct? i know it sounds stupid, but i didn't realize it at first when i got my 84 that there is a little cap under the screw off cap, it actully dips down in a bit and can hold fluid in it.
Old 07-09-2004, 02:46 AM
Katmandu's Avatar
Katmandu
Katmandu is offline
Yea, I did. It looks deceiving. Looks like it has more fluid in it that it really does. Anyways, the fluid level in mine is OK.
I'll double check on that throwout bearing idea tomorrow.
BTW, which direction does the fork need to go to raise the engagment point (to move the pedal higher) ??
Old 07-09-2004, 07:04 AM
bremen242's Avatar
bremen242
bremen242 is offline
does it grab insantly, or just start slipping 2" off of the floor?
Old 07-09-2004, 03:16 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
It grabs instantly.
Old 07-09-2004, 04:16 PM
FordF150Fixer's Avatar
FordF150Fixer
FordF150Fixer is offline
The sheet metal in the area where the master cylinder mounts to the firewall can be weak from fatigue. Observe the cylinder as a helper operates the clutch. If the sheet metal flexes and allows the cylinder to move forward, that may be your problem. If that is the problem, it can be fixed by re-enforcing the sheet metal from inside the firewall.
Old 07-09-2004, 06:07 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Roger that. That is what a mechanic at a trannsmission shop also said.
He said that there is a "KIT" from Ford to fix this firewall problem.
Anyone ever heard of this Firewall repair "KIT" from Ford ???
Old 07-09-2004, 06:51 PM
the84prjcttrk's Avatar
the84prjcttrk
the84prjcttrk is offline
Put a bolt on the fork (drill a hole) and put a lot of washers on it...and adjust it to the length you need it to be. I had that problem with my 84 f150. It might be rigging it but I have had it like that for almost 6 months now and had no problem with it at all. If it is giving too much clutch or not enough just adjust your washers to either side. It works great on my truck.
Old 07-09-2004, 06:53 PM
the84prjcttrk
Exclamation
*****make Sure The Whole Bolt Is Covered In Washers!!*******
Old 07-09-2004, 07:17 PM
FordF150Fixer
Katmando; I'm not aware of a "kit" to re-inforce the firewall. But, I fixed mine by placing large diameter washers over the mounting studs under the dash. I had to grind a little bit on the washers for clearance but the washers did the trick on my '84.
Old 07-09-2004, 09:06 PM
bremen242's Avatar
bremen242
There was a kit. I don't know if it is still available or not. Try your local ford dealer.
The other fix would be to weld up the seam of the crack and/or bolt on about a 3/16" plate to the inside firewall, behind your brake booster/clutch master to strengthen the firewall. I've had 2 manual fords, and neither have had the problem, so I can't give you any other hints.
Quick Reply: Need Help with my SUICIDE Clutch!
