Will they put the same ??
Old Jul 8, 2004 | 09:36 PM
JerNla's Avatar
JerNla
Ok, I dont know if anyone else has had this prob. but when I first start my truck or turn the key to where the radio gets power, the cd player begins to want to take a cd, it starts whiring like you are attempting to put a cd in but are holding on to it. After about 10 sec. it stops and displayes "Eject Error" then you can go about 10 more mins and it will start again, it will do this over and over till you put a Cd in it the it will stop and do everything just fine. It also wont do it if it allredy has a CD in at start up.
Ok now for the questions!! 1. Does anybody else have this prob. 2. I have a great warranty that covers the sound system, with a $50.00 deductable, would the unit cost more than that(Stupied question) and 3. Would they put back the same kind of player same model and everthing. The reason for that is I have heard the Audiophile and in my opinion it doesn't sound as strong as the MACH
(Allthough they are said to be the same !!) I love my unit that I have now, just hate the annoyance!
And I am sorry for the lengthy post ! I tend to get carried away! Thanks for any responses!
2000 EB MACH 6 CD, 1 IN DASH
Old Jul 9, 2004 | 01:59 PM
LV Dan's Avatar
LV Dan
I have not opened one of those CD players up, but usually a loading problem as you describe is the result of either a failed sensor or something blocking a sensor that tells the CD player a CD is being loaded. The other possibilty is that the loading mechanism cannot fully move to the eject position due to something blocking it.
If you did not have a warrenty and wanted to try and fix it yourself, blowing a little air into the opening for the CD might clean the areas enough to solve the problem. Use a can of compressed air that can be found at an office supply store. When blowing the compressed air into the slot, do not stick the plastic tube too far into the slot or you could damage something. Move the tube into a couple of different places and pull the trigger briefly. Do NOT shake the can, move the can, or turn the can sideways or super cold frozen liquid will spray into the CD player and hurt it further. For those that know how, removing and opening the CD player will yield better cleaning results.
If you have a $50 deductable on your warranty, I would take the unit in to be repaired or replaced. I would not even attempt a repair and risk voiding the warranty. A new player of equal quality will cost 8 to 10 times the deductable.
GucciSock
Sep 18, 2023 10:58 PM
Casper99
Dec 27, 2016 06:56 PM
ojh
Jun 24, 2016 02:56 PM
oneofakind97
Nov 26, 2005 07:32 PM
