Bed Bolt Identification Help
Old Jul 8, 2004 | 03:53 PM
NY-Ford-Lifer's Avatar
NY-Ford-Lifer
Question Bed Bolt Identification Help
Anyone know what tool I need to remove the bolts that hold the bed down? I wish to remove the front two closest to the cab in order to hold down a toolbox. I thought they were Torx bolts but none of the Torx bits I have fit (either too big or too small).
Old Jul 8, 2004 | 10:08 PM
xtreme1's Avatar
xtreme1
They are torx but i belive they are metric sizes. you could call a local linex or rhino installer and they will tell you.
Old Jul 8, 2004 | 10:25 PM
NY-Ford-Lifer
Thanks. I managed to get them free this evening.
Old Jul 8, 2004 | 10:51 PM
03f150man's Avatar
03f150man
Ny Ford Lifer--what size where the 2 bolts? are they nonstandard torx sizes or ? thansk
Old Jul 9, 2004 | 09:14 AM
NY-Ford-Lifer
Torx 50 worked although a bit loose. I went out and got a T-55 size to see if that was the missing part but it was too big.I used a very extension to avoid shearing off my knuckles and a 3/8" drive breaker bar. Some downward pressure and slow turning broke them free without and damage at all. I tested on one closer to the tailgate that I don't plan on using to hold down my toolbox in case I did damage it but I didn't. I just didn't want to put any further holes into the bed when mounting the toolbox so I used what is already there. Only problem know is getting the holes threw the drop in bedliner I'm having installed this weekend. Anyone know if these bolts are used to hold in the bed liner (if not I'll need to back them out)??
Old Jul 9, 2004 | 10:31 AM
ieee_raider's Avatar
ieee_raider
I have the Ford drop-in bedliner and there are no bolts holding it in.
Only the lip of the bed holds it in.
JockD
Oct 6, 2015 11:35 AM
ajordan193
Apr 4, 2010 04:17 PM
Jaaaaaaackman
Jul 15, 2006 07:38 AM
04superduty
Sep 25, 2004 01:51 PM
99f350sd
Dec 3, 2003 03:54 AM
