I put Valvoline mercon v in my truck, it didnt say durablend on the bottle but it did say it was a syn blend. I cant remember if it was a dual rated mercon/ mercon v or a straight mercon v. Valvoline only shows a dual rated atf on their website now. I know on the front of the bottle it said for 1996 and newer Ford vechicles, and the lettering was green. I bought this stuff at Advance Auto parts but they have been out of it for awhile now. I sure hope this is a mercon compatible atf, anybody know?
Valvoline has never offered a strictly "Mercon"-only product. Its always been a dual-rated ATF.
FWIW, I tried the Valvoline dual-rated stuff in my Ranger's 5R55E tranny, which requires "Mercon V", and I had less-than-satisfactory results with it. I changed it out and went with Castrol Mercon V and the difference was quite noticeable, in a positive sense.
I've been using the Valvoline Merc V with very good results in my F-150 4r70W tranny. I dropped the pan and cleaned it up and replaced the tranny filter at the same time.
Last night I flushed out the oem tranny fluid (82K miles on the stuff, I just bought it used)in my wifes taurus (AX4N). It was some of the blackest stuff I've ever seen. I dropped the pan, replaced the filter and cleaned up the pan, flushed in 14 qts of Valvoline Merc V, and now it runs great.
4r70w is what I got, did yours call for mercon or mercon v. I know ford says dont use a dual rated mercon but valvoline says its okay and I guess other people have used it with no problems but I dont want a tranny rebuild 30,000 miles down the road either. I still might switch back to regular mercon.
Ford's tranny engineer, Mark K. stated that Ford's long term durability testing showed the 4R100 clutches going out long term (like 50,000 miles) when MERCON V was used.
So, this is not something that you will see right away (if at all).
