Lightning Computer
And in general, SD will produce better performance in stock form. This is common knowledge among Mustang enthusiasts. If for no other reason, than the screen on a MAF meter restricting air. I've read in several publications, from the Motor Trend genre, to Muscle Mustang and Fast Fords. It used to be something we all just "thought", when the '87 and early '88 cars would run a little better, but at that time it was just a myth. But now it has become common knowledge. Usually the numbers are minimal, something like 5-7 horsepower.
It was also one of the things that contibuted to the decrease in the HP ratings if the 5 Liter Mustang in '91.
But this is a truck forum, so Ill shut up now....sorry
And also according to those books, MAF is more efficient and better at making power. The little screen on a MAF meter doesn't restrict much airflow, the air filter does a lot more. I put a MAF conversion kit on my truck and it made a very noticeable power increase from just the conversion. The trucks and 5.0 mustangs have the same EEC-IV EFI system.
Think about it, the SD system is pre-programed with certain engine parameters. It says to itself, I have X amount of throttle, Y amount of vacuum, Z amount of load, and with a few other sensors inputs decides how much fuel to put into the engine. It does not know how much air is really going into the engine, which is therefore a little inaccurate for making the air/fuel ratio perfect.
The MAF system directly measures the amount of air entering the engine. It is able to know exactly how much air is going in, and what amount of fuel to add. The only time MAF is not considered superior is in high hp 5.0s that are full out race cars. The race team has their own computers to burn/program computer chips for the SD. They'll change the programing often, even just based on the weather, so they're very critical. They do mention that they prefer the SD in that situation so they don't have the MAF sensor's whatever amount of restriction, but this is full out race teams with gobs of money to spend on computer chip programing, and worry about every single hp they can get...this is not realistic for us.
SD is not more efficient/powerful than MAF in stock form. Why do you think they swapped from SD to MAF in the first place, its on everything now...the reason they did is because MAF creates lower emissions, lower emissions means a more efficient/powerful engine. The big power maker between the two is the multi-port (sd) vs sequential (maf) injection.
If you really want to know the truth about Ford's EFI...get those books. They're available from Motorhaven.com.
There is a thread in the 87-96 forum about MAF conversion on the E4OD..check it out.
Another good reference is "The Official Ford Mustang 5.0 Technical Reference and Performance Handbook".
The general statement that MAF is more flexible and capable is true, and it has the potential to be more efficient and produce more power, I agree with that.
