engine stumbles when full throttle applied
Old Jul 3, 2004 | 07:53 PM
460_Sprout's Avatar
460_Sprout
Hey everyone, I have a 460 that is basically stock and has a Holley 4 barrel carb, not sure if this is stock or not. Anyways she fires up and idles great, starts out at about 1000rpms, then when you tap the gas the idle drops to about 550rpms. MIght need to adjust the idle a bit but its not bad. Anyways when you give it a lot of gas it wants to die out, if you give it gas slowly its fine. Happens whether I am driving or just idling. At first we thought the timing may have been off, I checked it today and my timing is currently at 12 degrees.
Not sure how many miles are on this motor but its looking a little tired, the seals are all starting to leak, the motor is damp everywhere with oil. I just replaced the distributor cap and rotor, as well as the plugs. Any one have any idea why it woudl miss like this with sudden throttle?
Old Jul 3, 2004 | 11:18 PM
Putt's Avatar
Putt
Most likely culprit is the accelerator pump in the carb, next would be bad vacuum advance on the dizzy, remote poss. is the cam timing is retarded from wear. HTH
Old Jul 3, 2004 | 11:31 PM
460_Sprout's Avatar
460_Sprout
how do you check the accelerator pump? Vac on the dist is good and timing shows 12 degrees with no vac and about 28-30 degrees with vac.
Old Jul 4, 2004 | 12:24 AM
High_Horse's Avatar
High_Horse
Your idle is a tad low, should be around 650-700. Sounds like your floats in your bowls need adjusting/sychronizing. Holleys are known for needing attention like that. How big of a Holley is it? I used a 650 on my 460 in a 79' Bronco and it screemed. I had to adjust my floats right out of the box. I believe you can go to Holley and download a schematic w/specs.
Old Jul 4, 2004 | 12:32 AM
Piffery1's Avatar
Piffery1
Blown out power valve
Try replacing the power valve in the 4180 carburetor. Get the list number off the carburetor body and contact the Carburetor Support team at carburetor@holley.com and ask for the proper Holley power valve part number that is calibrated for your particular unit. Aftermarket power valves may not be set up for activation at the proper vacuum levels. The 4180 uses a two-stage power valve.
To get an idea about accelerator pump operation, remove the air cleaner and look down the front two barrels (engine off!) while rapidly operating the throttle linkage; you shoulg see gasoline being pumped into the carburetor throats.
Piffery1
Old Jul 4, 2004 | 03:24 PM
LxMan1's Avatar
LxMan1
Does your vac. adv. have vacuum at an idle? If so, that can cause problems. Your timing will actually retard when you accelerate instaed of advancing.
With the engine off, look down the front barrels, open the throttle, gas should shoot out of the squirter down into the carb.
Old Jul 4, 2004 | 04:43 PM
460_Sprout's Avatar
460_Sprout
OK I did some searching, I should have a Holley 4160 600cfm 4 barrel carb, and from the pics I have found this looks right. A lot of the vacuum ports on the carb are plugged as the guy who had it before me removed a lot of excess stuff not needed, mostly smog stuff I believe so everything is plugged. I will do the checks you guys reccommend and see what happens.
On a side note, the adjustments screws on each side of hte carb, according tot he picture diagram they are called Idle limiter cap and idle adjustment screw, I thought these were the aitr anf fuel mixture adjustment screws? I adjust idle on the throttle stop screw, are the A/F mixture screws just called idle adjustment screws instead? When we turn them it effects the way the motor runs so I am assuming they are the mixture screws. On both sides at the front of the carb.
Sorry guys, I am not old enough to know carbs to well, I am used to EFI motors.
Old Jul 4, 2004 | 10:51 PM
Putt's Avatar
Putt
Those two screws are the idle mixture screws, they should be out about 1-1 1/2 turns from LIGHTLY seated. The vac advance can should be hooked to a port above the mixture screw on the pass. side of the carb. It will not have vacuum at idle. The list number( Holleys ID number) is on the front of the choke air horn. Do yourself a favor and get Holley replacement parts when you need them. JMHO
Old Jul 5, 2004 | 06:43 AM
460_Sprout's Avatar
460_Sprout
yeah I was thinking of getting a rebuild kit and rebuilding the carb.
Old Jul 5, 2004 | 11:24 AM
LxMan1's Avatar
LxMan1
The two on the sides of the carb are the mixture screws. Sometimes they have plastic inserts that limit how far that you can turn them, but they can be pulled out.
Post the LIST number off of the front of the choke horn and I can give better details.
CONFTIM1
Alternative Fuels, Hybrids & Mileage
Jun 15, 2006 01:36 PM
DictatorDanny
Computer Chips & Tuners
Jan 11, 2005 07:37 PM
black460
16
Dec 6, 2004 05:50 PM
riggermortis
Sep 29, 2004 05:27 PM
flat6
Jun 30, 2004 11:24 AM
