Tune up specs?
Old Jul 3, 2004 | 02:36 PM
64y292's Avatar
64y292
Tune up specs?
I cant find my specs, anyone know the valve lash for a 64 292. Cant remember for sure is the timing 6-8* and the gap .017. Any help would be appreciated.
Thanks
Old Jul 3, 2004 | 03:24 PM
Janet40's Avatar
Janet40
Thanks
The valve lash is supposed to be .015, but i disagree, i personally don't adjust mine that way. The way i adjust mine, is run it, and with a socket wrench back it off until it taps, then tighten in just slightly until tapping stops, that way you compensate for your engines oil thickness, your weather, and the wear you may have on your rocker shaft, i also time both of mine by hand, because of using unleaded fuels, i advance it out to the point to where it runs its fastest, then retard until it wont clatter when you're running it hot. Everyone else use your gauges, but i do it this way, because it's the right way!!.What most people don't realize is that when those specs were written, that was in the fifties right after they dropped the flathead, and it was 50 degress outside and they were using old time, non detergent straight 30 weight oil and timing was based on the leaded fuels around way way way back then, those specs by book aren't worth the paper they are written on, sorry...Janet
Old Jul 3, 2004 | 04:03 PM
312's Avatar
312
ill give you what they call for and you can decide.lash 019 hot 020 cold.timing around 6 points 015.
Old Jul 3, 2004 | 05:57 PM
Janet40's Avatar
Janet40
312, he does deserve to have the right specs, (wake up Janet), i actually forgot the timing, because i guess im lucky, and both my Yblock cars haven't given me any trouble at all and it's going on 3 years for both. I just see so many folks with worn Yblocks, and slack in timing chains, sorry fuel at fuel stations, and so many Yblockers have bad bad rockers. Can you believe i've been lucky on both Y cars for 3 years?? Other than me changing plugs and points..I forgot to add i changed to delco remi alternators, called the self exciter one post...Janet
Old Jul 7, 2004 | 05:42 AM
f700's Avatar
f700
tune up specifications for 1964 / 292
hi just looking in my book its firing order 15486372 , breaker gap= .o15
tining =6 valve clearance hot or cold =.018 hope this helps ps i have lotsof specifications for fords ok
Old Jul 7, 2004 | 10:58 PM
64y292's Avatar
64y292
Thank you all for the info, Maybe this will get her back to her old self.
Old Jul 8, 2004 | 05:25 PM
Janet40's Avatar
Janet40
But it matters a whole lot, if the rocker shafts are worn and or the rockers, if they're worn you would be wasting your time....Janet
Old Jul 8, 2004 | 10:44 PM
64y292's Avatar
64y292
They are not worn, it only has 63,482 original miles. I just like to make sure everything is like it is supposed to be once a year.
Shadowrider123
Sep 11, 2016 12:28 AM
Shadowrider123
16
Jan 12, 2015 07:30 AM
Scottbmcd
Aug 12, 2014 10:35 PM
mgerdau
May 11, 2014 02:13 PM
64F-100
Nov 5, 2008 06:38 AM
