fuel pump
Old Jul 2, 2004 | 12:48 AM
psycocrazy's Avatar
psycocrazy
fuel pump
just wonderin......
sometimes, when i go to take off, my truck acts like it has NO power, like when i floor it, it acts like im barely hittin the gas, so i was wonderin if that could be the fuel pump or filter, or maybe a loss of power from the leaky valve cover gaskets. and yesterday, when i took off, not even floorin it, it backfired like 3 times. not a major deal, my mechanic is supposed to look at it while we go on vacation, i was just wonderin if there was somethin relatively easy that i can do to make myself not look like an idiot when i pull into traffic.
any help, or ideas would be great.
thanks yall
psycocrazy
Old Jul 2, 2004 | 08:24 AM
Vin 95's Avatar
Vin 95
back firing can be a sign of the timing being off ,possibly the belt jumped a tooth,this will also cause loss of power.what year is your truck,? what engine? how many miles?
Old Jul 2, 2004 | 10:11 AM
psycocrazy's Avatar
psycocrazy
89 ranger, 2.9, with about 20000 on the rebuilt motor and 12000 on the rebuilt tranny
Old Jul 2, 2004 | 05:47 PM
Vin 95's Avatar
Vin 95
Is this a contsant problem or once in a while? I can tell you its not caused by your valve cover gasket either way.It sounds more like an electronic problem.
Old Jul 2, 2004 | 05:51 PM
Vin 95's Avatar
Vin 95
Oh yeah, are you getting any engine codes? Auto-zone will read them for free.The check engine light does'nt have to be on for you to be getting a trouble code.These codes will help find the problem,such as MAF sensor,bad fuel injector,etc.
Old Jul 2, 2004 | 08:43 PM
Ken00's Avatar
Ken00
Did you check the ignition timing?
Old Jul 3, 2004 | 11:59 PM
psycocrazy's Avatar
psycocrazy
freakin electrical problems....... how do i check the timing, i know stupid question, but ive never had to do it before, and it only does it when i first take off, through first gear
Old Jul 4, 2004 | 06:24 PM
Ken00's Avatar
Ken00
To check the ignition timing you'll need a timing light, can you borrow one?
Does it have normal power in the other gears?
Old Jul 4, 2004 | 11:43 PM
psycocrazy's Avatar
psycocrazy
im not sure if i can borrow one, i think walmart may sell them. it runs fine in the other gears. what else would messed up timing cause?
Old Jul 5, 2004 | 07:25 PM
Ken00's Avatar
Ken00
If the timing was off you would notice power loss all the time.
Anyone have an idea on this problem?
Old Jul 5, 2004 | 07:56 PM
Dave257's Avatar
Dave257
Hummm, Is it a automatic, could it be the torque converter is not working right? I don't know much about autos, just an idea. I think the backfire is the key, timing on either the valves or the ign. Has it backfired anymore?
Dave
Old Jul 5, 2004 | 11:17 PM
psycocrazy's Avatar
psycocrazy
nope no back fire, , but since i dont have exhaust on it, i can hear it kinda making a chugging noise like it wants to stall or something when i take off. if i let off the gas, its ok until i try to go again. and it seems to take a little longer to shift outa first than it should. any ideas on somethin i can do? and its an automatic 2.9, with everything rebuilt in the last year except the rear end.
Old Jul 11, 2004 | 02:42 PM
psycocrazy's Avatar
psycocrazy
ok now im noticin a slight power lossin all the gears, but that could be do to having my windows down, anyone got a solution?
Old Jul 11, 2004 | 03:10 PM
Vin 95's Avatar
Vin 95
Could be the throtle possition sensor (TPS) you really need to pull the codes to track down the problem.
Old Jul 11, 2004 | 09:49 PM
psycocrazy's Avatar
psycocrazy
ill try to pull the codes on monday after work. the check engine light just came on tonite, so ill find my code reader and check it out tomorrow and let yall know
