Lowering a E-150
Old Jul 1, 2004 | 09:47 AM
camprats99's Avatar
camprats99
Lowering a E-150
Does anyone know how I could go about getting a 1999 E-150 lowered. I want to improve the looks by bringing the ride height down. Thanks
Old Jul 1, 2004 | 11:38 AM
ken04's Avatar
ken04
I have an E-350 ext length V-10 that I plan on doing the same thing to. I have been told that alot of the suspension parts are the same as the F-series. So F-150 parts may fit. Stop by a good suspension shop that specializes in lowering trucks. You should be able to get some dropped spindles and shorter springs for the front. The back should be easier, probably just replace leaf spring pack. Obviously you have to check the bump stops and clearances but even though the frames are different, I believe alot of the suspension parts are interchangable with the F-series, good luck, Ken
Old Jul 10, 2004 | 10:52 PM
ACESN8S's Avatar
ACESN8S
Try chassis tech, http://www.truckn-store.com/product....t.asp&ID=58825
98Econoline150
Jun 1, 2015 10:09 PM
David Mchone
Mar 4, 2012 07:52 PM
Rexman
Aug 13, 2011 05:54 PM
kcbillo1
Nov 14, 2006 08:48 PM
Ron
Jul 15, 2001 07:43 PM
