Fire in air duct
Fire in air duct
The other day smoke started coming in the right side duct on my 1988 150 Econoline. Smelled like insulation burning, but not absolutely sure. I shut off engine immediately and waited five minutes, then drove home and parked. Next day I starated it. AC and blower still work fine. Whats the easiest way to find the origin of this smoke? Is it possible an obstruction could have caused the fire and if so, what could get hot enough to start the obstruction on fire?
Sometimes debris will find it's way to the blower motor speed resistor assy. When it hits those hot resistor wires smoke is produced. Sometimes the airflow to the resistor is cut off and the resistor assy melts or melts part of the housing.
You will need to take your blower motor and heater box assy apart.
