1978 - 1996 Big Bronco
Help No Spark Whats Wrong
Old Jul 1, 2004 | 12:30 AM
MRMUSKIE32's Avatar
MRMUSKIE32
Question Help No Spark Whats Wrong
I HAVE A 89 BRONCO W/302 EFI THERE IS NO SPARK. I TURN IT OVER IT SOUNDS LIKE IT WANTS TO START BUT IT ACTS LIKE THERE IS NO SPARK OR GAS GETTING THERE FOR IT TO START IT JUST DONT.ITS NOT THERE FUEL PUMP THAT TURNS ON SO I CHECKED THE SPARK AND THERE IS NONE. I CHANGED THE DISTRIBULAR MODGULE,SPARK PLUGS,PLUG WIRES, IGNITION COIL.IS THERE ANY THING ELSE THAT I CAN CHECK OR CHANGE TO GET HER TO FIRE UP? HAS THIS HAPPENED OR SOMETHING SIMULAR TO ANYONE ELSE.
PLEASE HELP
THANKS MIC
YOU CAN EMAIL ME IF THERE IS SOMTHING ELSE YOU NEED OR ? ABOUT THE PROBLEM.ITS MRMUSKIE32@AOL.COM
Old Jul 1, 2004 | 10:02 AM
Kemicalburns's Avatar
Kemicalburns
Take off the Caps dude.
ok, have you changed the cap and rotor? get a code reader and pull some codes the computer might give you an idea of whats up. also take the dizzy cap off and turn the motor over to make sure the rotor is turning . do you have a haynes manual if not get one they are great.
Old Jul 1, 2004 | 04:46 PM
MRMUSKIE32's Avatar
MRMUSKIE32
Yeah The Rotor Turns, I Put A New Distributar Cap And Rotor On Today And Still Nothing... Any Other Ideas?
Thanks Mic
Old Jul 1, 2004 | 04:48 PM
Kemicalburns
did you replace the tfi module on the dizzy
Old Jul 1, 2004 | 04:50 PM
MRMUSKIE32's Avatar
MRMUSKIE32
What Is The Tfi? What Does It Look Like?
Old Jul 1, 2004 | 04:54 PM
Kemicalburns
its a grey plastic piece that is on the side of the dizzy . the wire hareness plugs into this. go here http://fordfuelinjection.com/index.htm its red in this picture though clck on Actuators on the right side of web page and scroll half way down
Old Jul 1, 2004 | 05:00 PM
MRMUSKIE32's Avatar
MRMUSKIE32
Yes That Is The First Thing I Changed!! Any Other Ideas?
Old Jul 1, 2004 | 05:06 PM
MRMUSKIE32's Avatar
MRMUSKIE32
Alrighty, Thanks For The Input!!!
Mic
Old Jul 4, 2004 | 06:37 PM
MRMUSKIE32's Avatar
MRMUSKIE32
well guys,
thanks for the info, i had my dad come from Rochester, Mn since he is a mechanic and has all sorts of tools and computers to check the engine with and all, he was giving me ideas to try over the phone and then he decided it would be easier to just come here and check it since we couldnt get it and i wanted to be able to put the boat in this weekend... So i just wanted to let you know we got it fixed and it was the whole distributor and replaced it and voom voom she started right up... i just thought i would let you all know what it was incase you all might have the same prob. someday... i also wanted to say thanks to you all for tryin to help me...
thanks
mic
Old Jul 6, 2004 | 09:41 AM
Kemicalburns
Glad you got it running
right on!
DerbyTracr
1997 - 2003 F150
Oct 25, 2012 08:12 AM
65fastback302
Apr 2, 2009 11:53 PM
mikeyDWG
Exhaust Systems
Jul 12, 2004 05:16 AM
FordF10054
Dec 5, 2003 10:07 AM
