Sponsored by: Auxito
Long term storage
Old Jun 30, 2004 | 03:50 AM
pete bolen's Avatar
pete bolen
Long term storage
I'm going to be leaving the country for two years while working for the U.S.Army. I may get back state side for one month after being gone for one year. I want to store my 2003 SuperCrew which has 18000 miles on it and has a 5.4L Triton. I'll be using a U-Store it unit. I know about the moth ***** in the engine bay and in the cab and exhust to keep the mice out. Also the gas stablizer. Can you give me any other ideas. Thanks for a great web site. Pete Bolen.
Old Jun 30, 2004 | 05:59 PM
triton_2002's Avatar
triton_2002
Maybe put it up on jack stands so the tires don't get flat spots and take the battery out.
Old Jun 30, 2004 | 06:20 PM
vcrisis311's Avatar
vcrisis311
maybe you can shrinkwrap your entire truck
Old Jun 30, 2004 | 09:26 PM
ronxp2000's Avatar
ronxp2000
I would put something on the floor, as concrete draws a lot of moisture..............perhaps a big sheet of plastic, with some cardboard or carpet below the plastic to contain the moisture.
Old Jul 1, 2004 | 08:12 AM
lariatrider's Avatar
lariatrider
Definately put it on jack stands, if you are going to be gone that long the tires very well could form flat spots. One thing you should check into though instead of letting the air out, see if there are any shops that fill tires with Nitrogen instead of air. Nitrogen contains very little moisture and does not expand or contract with heat or cold as does air. Moisture degrades the rubber and rusts steel belts inside tires if exposed. Most shops that do this, charge about $50 or so. Say, where do you live, maybe someone could drive it around the block once a week or so.
Old Jul 1, 2004 | 09:22 AM
superrangerman2002's Avatar
superrangerman2002
Welcome to FTE!
What ever you decide to do, make sure that you make a list of the things that you did, and leave it on the front seat of the truck so that you know what you need to undo. Make sure to note locations of items placed, like rat bait, moth *****, etc.
I would reccomend:
1. unhooking the battery
2. jack the truck up using the frame on the front, and the axels on the rear
3. pull the valve cores out of the tires and let all air out, it is best to not have any air at all.
4. replace oil filter and drain crank case, then fill the motor as full of oil as possible.
5. Moth *****, mice and rat bait, and steel wool placed at stratiegic places in vehicle and areas of the storage unit.
6. Wash and wax and a really good vaccuming of interior (want to remove any thing that may attract rodents.
7. Large secitons of card board and plastic under the truck and one large sheet of plastic over the top of said vehicle to keep off the dust and possible bird bombs.
Old Jul 1, 2004 | 09:31 AM
christaylor's Avatar
christaylor
I would be willing to sacrifice by not driving my beat-up 95 and drive yours while your gone . Thanks for giving you rtime to the military.
Chris
Old Jul 5, 2004 | 10:02 AM
JustinH's Avatar
JustinH
don't put plastic on the truck, the paint needs to breathe, get a car cover.
Also raising the truck and leaving it lifed in the air is not a good idea either, it will make the suspension sag.
If you are not concerned with the tires, then just over-inflate them and take you chances with flatspots. Otherwise purchase a junkyard set of spare tires and let them sit on that.
If the truck is indoors I wouldn't worry about rodents too much.
Just change the oil and filter right before you store it with a high quality diesel oil (delvac, or rotella). This meets gas requirements and has a high additive package which is excellent for storage.
Also fill the gas tank up with gas, and add a can of stabil fuel stablizer and leave it be.
Have a good trip and come home safe.
Old Jul 5, 2004 | 10:59 AM
PaulC's Avatar
PaulC
Remove the battery, and bring it home with you. Removes the possibility of an electrical fire, and makes life more difficult for those who would want to borrow your truck while you are gone.
Alec Bolen
Feb 1, 2017 10:15 PM
Pete Kildow
Feb 26, 2016 03:25 PM
Pete Roberts
Feb 23, 2011 02:13 PM
okie pete
15
Oct 9, 2010 07:43 PM
F150pete
Apr 4, 2001 09:22 PM
