running hot
Old Jun 29, 2004 | 08:17 PM
wayneasbell's Avatar
wayneasbell
running hot
My 77 f100 with 351m continues to run hot after a recent engine swapp. I installed a rebuilt engine from Advance Auto. I have a new water pump, new radiator, new thermostat, new hoses, new fan clutch. My mechanic friend says that maybe exhaust is leaking into the water jacket and causing it to get hot? There is no sign of water in the oil. I have a small leak in the intake manifold on the back side were it is flat. Could that be my problem?
Old Jun 29, 2004 | 09:51 PM
mark a.'s Avatar
mark a.
If the ex. is leaking into the rad. you can smell it with the cap off & it more than likely would be boiling over. I would do a pressure check on the cooling system first.
Old Jun 29, 2004 | 11:52 PM
FordPickup460's Avatar
FordPickup460
Welcome to FTE.
Why do you say it is running hot ? Is the gauge saying its hot, or is it boiling over or doing something else ?
Old Jun 30, 2004 | 06:11 AM
wayneasbell
boiling over
The temp gauge is not hooked up yet! the water boils out of the radiator!!! I have only drove it to work twice and it got so hot the engine started boiling the oil through the intake manifold leak. What should the preasure be on the radiator? Or are you refering to puting preasur on the radiator to see if it leaks air through the engine?
Old Jun 30, 2004 | 09:12 AM
beartracks's Avatar
beartracks
Part of the problem might be the tightness of a new engine. Check the oil pressure sensor behind the manifold to see if it is the source of the leak.
I would check the timing. Are you certain the thermo is facing the right direction?
I wouldn't drive it till I found the problem.
Old Jun 30, 2004 | 09:18 AM
73Custom's Avatar
73Custom
Does this mean it acted the same with the old engine?
Marty
Old Jun 30, 2004 | 01:10 PM
wayneasbell
The old engine did not run hot. What I mean by continuous is that I have not fixed the problem yet. The intake manifold gasket is pinched where it mates to the block on the rear side. There is a small amount of air leaking through it. Would the leak cause the boil over or do you think the intake leak was caused by preasure and it blew out the weakest point of the intake gasket?
Thanks,
Wayne
Old Jun 30, 2004 | 10:20 PM
mark a.'s Avatar
mark a.
The leak has nothing to do with the over heating problem 351/400 intakes are dry.Personaly I don't use end gaskets as they can cause this problem
weross67
Oct 26, 2013 06:14 PM
dodgdatona
Jan 15, 2010 04:19 PM
70T351W
Sep 4, 2006 05:48 PM
thebone
Jan 4, 2004 04:53 PM
jcheyn
1983 - 2012 Ranger & B-Series
May 10, 2000 03:57 PM
