Spark plug wire clips
Old 09-19-2002, 11:14 AM
SA Struck's Avatar
SA Struck
SA Struck is offline
Post Spark plug wire clips
I'm changing out the plug wires on my '99 Mountaineer (V8), and I'm having a heck of a time unclipping the wires. Is there any easy way to do this? I can't even get to the clips on the #4 wire. What a pain.
Old 10-11-2002, 03:19 PM
missviv2's Avatar
missviv2
missviv2 is offline
I had that same problem and then I looked inside my front wheel wells. There is a plastic cover on each side of the vehicle that protects the engine from the stuff that you run over. This cover is held on with plastic clips, like those that attach your door trim to the door. Once you pull on them (hard if you have to, I haven't broken or ripped anything yet) and take off the cover, the #3 and #4 plugs are right in front of you and so much easier to reach. This is the same on the driver's side for plugs 5, 6, 7, and 8. I hope this helps you.
Vivian
Old 10-11-2002, 07:42 PM
topo4u2's Avatar
topo4u2
topo4u2 is offline
I have a hint for plug installation....put an old rubber plug boot on the new spark plug. It will make the job a lot easier! It will be so much better to start the threads.
Mike: 1995 Explorer XLT,4.0 litre, 3.73 non-slip.
Old 10-12-2002, 02:44 AM
97 awd xlt blue's Avatar
97 awd xlt blue
97 awd xlt blue is offline
deerhuntre
2004 - 2008 F150
18
08-06-2020 04:27 PM
1986stepsidef150
07-27-2014 11:28 PM
granny_rocket
04-26-2013 07:57 PM
dae06
1983 - 2012 Ranger & B-Series
12-29-2011 10:56 PM
rbrondan
Electrical Systems/Wiring
01-10-2005 12:54 PM
Quick Reply: Spark plug wire clips
