question about a wire
Old Jul 16, 2014 | 07:49 PM
1986stepsidef150's Avatar
1986stepsidef150
86 f150 5.0 my truck has been running rich and rough and I can't figure it out. Looking over everything I seen a loose unconnected wire from the main harness where it plugs into the injector harness. The same amount of wires in the main clip as in the injector clip but the other wire is about the same length but I see no where for it to go. I'm not sure if it's supposed to or not. ???? The code I had was lack of tach to eca. Thanks for any info
Old Jul 16, 2014 | 08:24 PM
84StraightSix's Avatar
84StraightSix
what color is the wire? Maybe I can find it in my diagrams
Old Jul 16, 2014 | 08:28 PM
1986stepsidef150
I'll have to look tomorrow. It's at my dad's in his garage. I wrote it down but can't find it
Old Jul 16, 2014 | 08:32 PM
84StraightSix
Just a shot in the dark though considering your problem. Make sure the SPOUT connector is hooked up comming of your distributor. I have never been able to look closely at one of these engines so I dont know exactly what your talking about but maybe that wire is that connector
Old Jul 27, 2014 | 04:34 PM
1986stepsidef150
Just got around to looking at it. The wire is orange. Where the injector harness snaps into the main harness. This wire is coming from the main harness. It's not the spout it's up by the distributor
Old Jul 27, 2014 | 08:43 PM
Franklin2's Avatar
Franklin2
Look at it carefully. Does it have a faint white stripe? If so, it feeds power to the map, the tps, and the egr position sensor. On terminal #26. There is also a orange wire coming off the TFI module. My diagram says it's orange, the diagram below says it's black/orange.
Old Jul 27, 2014 | 11:28 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
This sounds strangely familiar. Had a fuel pump relay issue with my son's 86 F150 and found an orange wire disconnected by the left rear corner of the engine off the main ECU harness. Turned out to be the ground for pin 49 of the ECU. Grounds to the left rear corner of the intake manifold.
Christmas
Jul 17, 2018 12:34 PM
bkuuz1
Oct 2, 2014 09:23 AM
nevets350
May 17, 2014 05:47 PM
Big Ruth
Jan 22, 2010 12:48 PM
pdsq89f150
Jul 17, 2003 09:02 AM
